True 3rd function on MT 357?
   / True 3rd function on MT 357? #2
I don't see why a WR Long couldn't be installed.
https://www.(Temporarily blocked du...-3rd-Function-Hydraulic-Vavle-Kit-s/10178.htm
   / True 3rd function on MT 357? #3
I went with Summit for my 3rd function , very satisfied and good to go
Thanks guys...looks like these are both using the "power beyond" port on the tracker so that all 3 functions can be used at the same time. Where is the "power beyond" port on the MT series?
Another note...neither of the above kits are designed to work with tractors that have cabs
   / True 3rd function on MT 357? #5
MT240
My dealer is researching a true after market 3rd function that is not a diverter...I called a dealer in Tomball TX and they do them every day...so someone makes them. The ones they put on have 2 buttons, not just a single button to divert.
The only question they had for me was "does it have a cab or not?" apparently they use different products for cab or no cab
   / True 3rd function on MT 357? #7
doesn't matter if it's a cab or not . your mounting you valve and hoses outside the cab
and running your button inside to work off of your level arm
Dealer found one from WR long...but I am leaning toward the T494 now.
2022 Chevrolet Colorado LT Crew Cab Pickup Truck (A42744)
2022 Chevrolet...
Massey Ferguson 231 Tractor with Loader (A44391)
Massey Ferguson...
WICHITA TANK 500BBL WHEELED FRAC TANK (A45046)
WICHITA TANK...
Trailer (A44571)
Trailer (A44571)
2019 JLG 1932R 19ft Electric Scissor Lift (A42742)
2019 JLG 1932R...
PALLET OF PIPE FUSION EQUIPMENT (A45333)
PALLET OF PIPE...
