Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Soundguy, check out Henry's roofing materials. We used the roofing tar that has bentonite clay mixed in with it to seal our water tank. Over 2 years and no leaks yet. It just brushes on. Cheap, easy, and so far so good. /forums/images/graemlins/smile.gif
Good luck, Brian
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
</font><font color="blue" class="small">( One job ?
Rent a truck thats reliable.
)</font>
Only place that rents water tankers around here is cat.. and for a cool 1800+$ a month.. they'd haul one out for us. Since the thing will sit idle all but an hour a day.. that's like paying 1800$ for 20 hrs work a month. As I said.. this is a temp use thing.. just dropping some water on the roadway at peak traffic to control dust. If we rented one.. we might as well load it with money and let it fly out over the street /forums/images/graemlins/grin.gif
I'd vote for drylock also. Two coats. I put it on my basement concrete block walls with a big brush. It has portland cement and rubber in it. Can there be adequate ventilation while whatever you use is being applied?
Soundguy what kind of truck is it? All the sealers are good advice but if its about to be junked Id be interested in buying it if its road worthy. We need a water truck but the way we water a few pinholes wont bother us as we fill it up each run. Just give make model and year abd capacity. Id rather reuse it than see it go to the junk heap.
