I don't have my physics book right in front of me, but I believe if you double the length of the hitch reciever or the hitch, you are doubling the amount of leverage or working arm on the actual hitch reciever. Most hitchs are rated for 500 lbs. tongue weight and 1000 lbs. with a weight distribution hitch. I would think that you would be reducing the amount of physical tongue weight proportionally. If you doubled the extension, you would reduce the tongue weight capacity by 50%. I haven't had my 2nd cup of coffee yet so I may be all off on the wrong path here. But at least that is my story for now. /forums/images/graemlins/smile.gif When I was flying we had to figure weight and balance from charts using the weight and arm of cargo, fuel, and passengers dependent upon their postion in or on the helicopter. I would think the same process applies here. As long as you keep your tongue weight reasonable, you should be OK.
