Truck tire valve stems
   / Truck tire valve stems #1
ronchp
Limestone, TN
Mahindra 3616
Had the tires replaced on my 2500 HD truck a little over a month ago. Last week the wife wanted to go horseback riding with some friends, so i put 80 psig in the back tires to pull our gooseneck trailer. While i was at work, she used the trailer and went riding. Later that evening, after the trailer unhooked and truck sitting in the garage, the valve stem on one of the back tires ruptured. When i got home and looked it over, this was the first time i noticed the shop had installed passenger tire valve stems on the tires instead of high pressure valve stems. Just a reminder to be more observant than i was if you press up your tires to pull a trailer. Glad it didn't fail while she was pulling the trailer.
   / Truck tire valve stems #2
Good point. One time my tire dealer's helper put on the hub caps on my pickup, after new tires. They did not line up the notch with the valve stem. By the time I got home, the hub cap had cut into the valve stem, loosing most of the air. I was mad, but took the tire off and went back, they promptly put on a new stem. Later on I learned, a real good tire shop installs steel valve stems on any truck tire.
2007 CATERPILLAR 930G WHEEL LOADER (A51246)
2007 CATERPILLAR...
BESTWAY AG VSK50 LOT IDENTIFIER 94 (A53084)
BESTWAY AG VSK50...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
(4) STEEL CARTS (A51248)
(4) STEEL CARTS...
FORD 555B BACKHOE (A51406)
FORD 555B BACKHOE...
Deutz BF12L413F 19.1L V12 Turbo Diesel Generator (A51691)
Deutz BF12L413F...
