Truck tire valve stems
   / Truck tire valve stems #1
ronchp
Bronze Member
Limestone, TN
Mahindra 3616
Had the tires replaced on my 2500 HD truck a little over a month ago. Last week the wife wanted to go horseback riding with some friends, so i put 80 psig in the back tires to pull our gooseneck trailer. While i was at work, she used the trailer and went riding. Later that evening, after the trailer unhooked and truck sitting in the garage, the valve stem on one of the back tires ruptured. When i got home and looked it over, this was the first time i noticed the shop had installed passenger tire valve stems on the tires instead of high pressure valve stems. Just a reminder to be more observant than i was if you press up your tires to pull a trailer. Glad it didn't fail while she was pulling the trailer.
   / Truck tire valve stems #2
Good point. One time my tire dealer's helper put on the hub caps on my pickup, after new tires. They did not line up the notch with the valve stem. By the time I got home, the hub cap had cut into the valve stem, loosing most of the air. I was mad, but took the tire off and went back, they promptly put on a new stem. Later on I learned, a real good tire shop installs steel valve stems on any truck tire.
JLG 1255 Telehandler (A53472)
JLG 1255...
80in HD Tooth Bucket with Side Cutters (A53472)
80in HD Tooth...
JOHN DEERE 608C LOT IDENTIFIER 19 (A53084)
JOHN DEERE 608C...
UNUSED FUTURE FT13CJ EXCAVATOR (A51247)
UNUSED FUTURE...
2015 Freightliner Bucket Truck - Terex TM 100 Boom - Cummins Diesel - Allison Transmission (A53473)
2015 Freightliner...
UNUSED CFG INDUSTRIAL 12EX-ATA MINI EXC ATTACHMENT (A51248)
UNUSED CFG...
