Truck tire leaking at bead / balancing weight
   / Truck tire leaking at bead / balancing weight #21
If your rim is aluminum it most likely has a clear coat. wheel weights will marr the finish and allow water under the clear coat and make it peel. You will only know when you remover the tire. buff up the rim with a flap disc in the areas bubbled up and remount. do not worry about sealers. I have also seen this happen with chrome rims. quality is so bad that chrome will start to peel in under a year. factory or aftermarket.
Yes but Already resolved
post 14
two and 1/2 months back.
5030 called it in post #5
on November 20th.
Yep. Although the advice may still be appreciated by future searchers on this thread. In my case, I popped that side of the tire off the bead, sanded the area smooth with some fine (320 grit?) paper, applied bead sealer, and remounted. More than two months on, that tire has not lost any air, despite the winter weather that usually reveals all bead leaks. I've been checking it thru the TPS's almost daily.
   / Truck tire leaking at bead / balancing weight #23
Had that happen once after a rough winter—slow leak near the weight, right at the bead. Ended up breaking it down with irons and hitting it with a bit of bead sealer, held up fine after that. Might’ve been salt or just corrosion sneaking in over time. If it’s just one tire and you’re used to doing it yourself, probably quicker than hauling it in. I messed around with truck rental montreal a while back for a move and saw a few places that also handled heavier tire work too.
   / Truck tire leaking at bead / balancing weight #24
My tire story this week. The last two weeks I would notice a little out of balance up at highways speeds on my F250. I went to my property last week and on the return home suddenly had a bad shimmy around 63mph. At 71 it would mostly smooth out but around 63 it felt like the front end was going to shake apart. I talked to a guy I've known for a long time who runs a shop up in St Louis. He suggested tires. I had 47K on these junky Falkans. One tire was out of balance in both axis. So, four new Firestones and it's smooth as butter. Thankfully the front end is still tight and alignment checked ok. Truck has 157K on it. he did say my front shocks need replaced but I'll do that myself.
   / Truck tire leaking at bead / balancing weight #25
I was pleased with the last set of Falkans that I had. I never get more then 40-45,000 on a set of tires. Between dirt roads, fields and gravel driveways they all seem to start getting stone bruise flats by that time.
I guess I could update this thread, 18 months on. The sealed tire holds air better than any of the non-damaged wheels, now! Runner's bead sealer did the trick.
Per 5030's explanation, now I tell the dealer to ONLY use stick-on weights whenever replacing tires, but the damage to these wheels is already done. Do yourself a favor, and on any vehicle with aluminum wheels make a special request to use only stick-on weights, whenever you're having tires balanced. You can't guarantee the mechanic will actuall see or heed your request, but you can at least try to avoid this damage.
Manac Walking Floor Trailer (A50322)
Manac Walking...
22ft Rolloff Flatbed Body (A51691)
22ft Rolloff...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
