Truck snowplow on tractor front 3 point
   / Truck snowplow on tractor front 3 point
Doesn’t Meyer use the “blue oil”? Can that be drained from cylinders and regular tractor hydraulic fluid used?
   / Truck snowplow on tractor front 3 point #72
Imho, if someone offered me a Myers for free - I'd pass.
I doubt that the cylinders will care what color the oil is. Now they may have some special oil design for their pump with some kind of additive that might be helpful in a generally no maintenance situation (like a hardly used homeowner plow). But I've bought replacement angle cylinders by stroke and pin size. Never by specific manufacturer other than Fishers d/a cylinders. They may be available now in a "generic" version as well.
I was more concerned with the “blue oil” contaminating my tractor oil, if it ever made it back into tractor.
I could purge as much as possible from cylinders and lines.
I hear ya on the Meyer plow, but on this project, I’m just trying to put something to work to get the job done.
Would rather have a 10’ Western Heavyweight, but I can’t find any low price/older ones.
   / Truck snowplow on tractor front 3 point #74
You'll need longer lines anyway, and with the line removed and you collapse the cylinder the little bit left....
What's your tractor hy/trans hold, 20-25 gallons?
But I understand your point.
Can’t remember off hand, but 30+ gallons seems to be what I remember
   / Truck snowplow on tractor front 3 point #76
As long as the Meyer comes with the optional "welder attached" package you'll be fine. Poking fun aside the commercial Meyers I bought, an ex-State of Maryland plow, is a different animal than the pick-up mount type blades I had in the past. It's made of much heavier stock and in the 3 years of my use I cannot detect any wear on the edge.
And at around fifty bucks each I'd replace the power angle cylinders anyways.
   / Truck snowplow on tractor front 3 point #77
I'm not sure when, but Myers is now hooked in / bought by Diamond (or vice versa) and I believe has a new attitude that they better catch up with the rest of the crowd.
I remember as a kid about 45 years ago, seeing a Diamond (pickup sized) plow that iirc, puts the modern Fisher XV-2 plow to shame in its construction. It was a v blade that had the shorter middle and dramatically taller outside and the "wings" moved individually. I was very impressed as I admired it with my bicycle parked nearby 😁.
I found exactly ONE 10’ Western Heavyweight in a week of searching and it was sold when I called. Unless I want to spend $2500++
Not much else out there. Guess demand is high since winter…
   / Truck snowplow on tractor front 3 point #79
I hunted, shopped for a plow for my CUT and most every one was so trashy and over priced that I decided to DIY one.
OK, I did have an old industrial work bench so I cut that to size and had local shop form the blade
Also had them make the 'banana' ribs.
After scrounging my metal odds and sods I was able to DIY my own 7ft blade.
For lift I chain slung it from my FEL frame with the bucket removed for winter.
I even fashioned a back 'flip' back drag blade for squeaky clean back dragging.
As I recall my total cash layout was in the $200 range some 7 years back and it is still going strong and probably will outlive my CUT, and still rust free.
It is of the spring loaded 'flip style' design.
I did later modify it to have a wing or ear on one side to limit spills to only one direction and that sure saves time.
OK, the plow is for minor events as I have a 3pt blower as well.
That’s a great project!
I got an offer to road plow a large development to assist a big landscape contractor and need to be ready to go now. Luckily, it hasn’t snowed yet.
I already have a plow setup, but I always like a backup. The 10’ plow on the bigger Massey would be perfect on wide roads. One down the middle and one on each side.
INVERSION DEVICE (A58374)
INVERSION DEVICE...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
2006 TRANSCRAFT 48X102 SPREAD AXLE FLATBED (A58214)
2006 TRANSCRAFT...
Test Button (A55272)
Black Steel Diamond Plate (A55758)
Black Steel...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
