Truck rant. And don't know what to do.
   / Truck rant. And don't know what to do. #71
Wrong. At least with the Ford F150, it is the non-turbo V8 that has had recalls due to excessive oil consumption. Also with the GM trucks - the V8 engines with cylinder deactivation had oil consumption problems.
Kind of a let down after I had figured the Ecoboost was pretty much without fault. Audi (VAG) did settle a class action law suit (I'll forgo posting info here as others can, if they wish, actually find this kind of information via simple Internet searches).
   / Truck rant. And don't know what to do. #72
The truck you want doesn't exist yet.
I'm closing in on 80 years old and have had a lot of trucks in my time. They ALL have problems, if not sooner then later.
Canada is now averaging $1.50/L or about $6/gallon for gas.
I won't be looking for a gas guzzler as a commuter vehicle. Trucks are now pushing $100K once the dealer packages are added on and the monthly fuel bills end up being the equivalent of a mortgage payment you could have bought a house with.
Pretty expensive toilet paper.
My commute is 4 miles.
   / Truck rant. And don't know what to do. #74
When people say a F150 has a 14,000 tow rating, in theory it’s true. In reality, they don’t exist. As N80 has stated, it’s not that easy. I’d bet good money most F150’s have a rating between 8000 and 9000 pounds. The 14,000 rating is for an XL F150, no added options, regular cab long bed, heavy duty payload package, max tow, 3.5 eco boost, 2 wheel drive. You don’t see many of those on the lot.
If you start researching engine problems you will drive yourself insane. The hemi’s have had lifter, cam and valve problems. Common, no, but it’s there, usually at higher miles but not always.
The Ford 5.0 from 2018 and newer? They changed the way they lined the cylinders. It seemed they fixed it but the first couple of years, 2018 and 2019 some will use oil. I know someone that is adding 6 quarts between oil changes.
Chevy and their cylinder deactivation? Yeah, some are burning oil.
Toyota has had rust problems in the past. You can go on and on, they all have issues.
   / Truck rant. And don't know what to do. #75
Me too.
I've been contemplating replacing my 16 year old Jeep Wrangler with a new model. But reading about all the electronic problems on the Jeep forums scares me to death. Can you imagine? Out in your Jeep, a hundred miles from pavement, and this message comes up?
Guy said the Jeep shut down and had to be towed!
My 2008 F-550 6.4L did the same thing to me, twice. Sensor failures. Once was while towing a load of hay pretty far from home.
I dont know if itll make you feel any better, but Ive had a 2020 Jeep Rubicon a while now and not a single problem other than when we purchased it, the radio head unit failed along with backup cam and power mirrors. Fixed immediately by dealer. Has about 40k on it, so not exactly a ton of time, but I really like it. The new ones are pretty stout off road and a lot of fun!
   / Truck rant. And don't know what to do. #76
I have an 07 5.9 Cummins. A great truck and engine.
That would be a Dodge Ram truck. Yes, the Cummins is a reputable engine since forever.
Yes, as I've said, it is like code breaking to find out this information. And for whoever said that it is on the door placard I do not see that on any of the listings that show the door placard. You get weight ratings for front and back and then a lot of abbreviations that surely mean something but still probably don't reflect the actual number or added tow packages.
And in fact, some of the F150s are rated as low as 5000 pounds. I don't need a half ton truck that can pull 14,000 pounds. My trailer is not even rated that high. I need a truck that can pull a at least 8000, preferably 9000. Most of the common F150s in the charts are rated between 8100 and 9800. But I'm not going to spend my money on a truck in which I do not know whether it is 8100 or 9800. That is not a small difference. This is even more true when I look at Tundra specs and can easily know exactly what I'm getting in terms of towing capacity....and in all probability a better truck as well. At a cost of course.
I don't know why Ford insists on making this so hard. But, they sell a ton of trucks so apparently it doesn't matter to most people.
The heater in my Titan is magically working again and I'm not as pissed off at this moment and every time I mention getting a new (used) truck my wife groans and rolls her eyes. We just paid the Titan off this week.
   / Truck rant. And don't know what to do. #78
I would say most of the trucks you would buy would meet your tow requirements as long as it has the trailer backup knob, which comes with the two decent tow packages. But the way, I think the lowest tow package comes with just a hitch and the wiring, which is probably the one rated at 5000 pounds.
   / Truck rant. And don't know what to do. #79
The problem is that there are three levels of tow packages that change these ratings. It is very hard to tell what tow package a truck has if you don't have the dealer window sticker. I've been digging deep in the F150 forums and there is no clear consensus even among "experts". Plenty of tables and brochures presented but no real clarity. Even guys with new trucks find that they did not have what they thought they had. Anyway, even though I'm a Ford guy second after being a Nissan guy, I am writing Ford off, again, for this very reason. Even if, as you say, it can be determined with due diligence, it is ridiculous to me that that is necessary.
Window stickers are easily available for newer trucks:
Ford F-150 Window Sticker Generator
Or: Use your VIN number to get Ford Window Sticker
I don't know how new trucks are but newer cars suck !
GF has a 2015 Hyundai. It burns more oil than gasoline ! I know I'm stretching it a little, but to design cars to burn 1 qt of oil per thousand miles is just unacceptable to me .
When discussing this with the service Dept. , they claim it's normal these days. said they also own the Toyota store next door and toyota specs. the same .
I have owned vehicles my entire life and never had a vehicle to burn a qt of oil between 5 K changes.
So, I did a little research on the matter, and sure enough, car makers are building engines with less tolerances, causing less friction, which results in getting better gas mileage as mandated by the government !
Burning that much oil causes other issues, it shortens sensor life and spark plug life, and who knows what else !
I have no idea what you gain by getting better fuel mileage at the expense of burning more oil !
Are newer trucks required to meet these same gasoline mileage mandates ? IDK, but it may be worth checking into before you make the purchase. I found all my info on the hyundai forums
Hyundai specifically had issues with their i-4 engines, the rings wear much faster than they should and allow it to use oil, the only fix is a full teardown.
I call BS about newer cars burning oil. I’ve never had any vehicle that needed to add oil between changes, old or new.
Hyundai, GM, Ford and Dodge have all had recent issues, Hyundai with their oil control rings on the pistons, GM and Dodge with their variable displacement engines and Ford has had a couple different issues depending on the engine.
They all make good trucks and they all make occasional lemons.
Aaron Z
   / Truck rant. And don't know what to do. #80
Older models they used to list the gvw and gcvw of a vehicle on the door placard. To figure out towing capacity, you just had to subtract the gvw from the gcvw.
Looks like they quit doing it on the newer vehicles as someone pointed out to me.
2018 Freightliner Bucket Truck (A55973)
2018 Freightliner...
2014 Chevrolet Impala Sedan (A56859)
2014 Chevrolet...
Informational Lot - Shipping (A55315)
Informational Lot...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A56858)
2021 Chevrolet...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
Massey Ferguson 1745 Hesston series (A53317)
Massey Ferguson...
