Truck rant. And don't know what to do.
   / Truck rant. And don't know what to do. #61
2018 or newer F150 with that eco boost 3.5L all new design mostly working out the bugs in the engine. The six speed Ford transmission has been robust. I have no idea about the new-codeveloped with GM transmission.
My 2011 F150 with the original, flawed 3.5L eco-boost has been good on ride quality, needed a timing chain, guides and phasers at 120K. It shelled the 10" differential carrier this summer so I swapped in a Eaton True-Track and will never need to think about that again.
For the eco-boost engine (this is true of all turbo engines with an intercooler) drill a 1/16th hole at the lowest point in the intercooler. OEMs cannot do that due to emissions, but you can and in doing so will keep your intercooler working at peak performance. I also added the largest racing catch can I could get my mits on to redo the silly emissions that sent crankcase gasses back into the intake. In comparison to my original design, the new designed 3.5L fixes this, but this emissions issue builds carbon up on the backside of the intake valves leading to fouling. Ford fixed this by adding an injector that works like a choke on the warmup by adding fuel to the intake that washes any built up carbon off of the intake valves so no catch can is needed.
So anyway yeah, 2018 or newer F150. Rattle free and nearly any model out-tows your Nissan.
Also GM has a long-overdue class action against their small block V8s for wiping out cams for the last thirty years.
Dodges, I don't know nothing about their 1/2 tons but I don't see any 1/2-tons with 2-or 300,000 miles in my area.
   / Truck rant. And don't know what to do. #62
The thing that is putting me off from the Fords right now is that I digging and digging trying to find out the towing capacities of the various 2020 and 2021 versions are and it is almost impossible to tell. Even on the F150 forums there is utter confusion even when trying to buy a new one. Trying to get the towing specs on a used one would be just about impossible. Just trying to find out read diff gearing is driving me nuts. I have a hard time understanding why Ford does this. Three different levels of towing packages the contents of which are totally confusing. Multiple diff gearings with no rhyme or reason why and for what purpose and virtually no way of telling what a vehicle has on it without the original window sticker.
At this point Ford is out, again, unless someone somewhere can show me a fool proof way to know what one of them can tow. The used car salesmen are useless in this regard.
As far as GM and Dodge, well, you know how it is. You build up prejudices based on family and friends preferences. Growing up we were Ford people. My in-law who is a farmer switched from lifelong Fords to Dodges. Had 2 or 3 of them and nothing but trouble. My son-in-law's surveying company has had good long term reliability with Suburbans. But he only drives Fords. My best friend recently had a Suburban that required engine and transmission replacement. He ditched it for an Excursion.
So hard to know. So hard to get past the anecdotes and lifelong prejudices.
Might just have to bite the bullet and go Toyota.
They publish the towing on the backside of their brochure. Its like 13,550 towing pounds for the heavy-half and something like 11,500 for regular half. My eleven-year-old F150 is rated at 11,000. It is also on the door sticked on the drivers jam of every F150. The trucks tow well over their limit but chew up tires doing so. But they ride nice, so there is a trade-off.
   / Truck rant. And don't know what to do. #63
For those of us who want something enclosed and don't need to haul overly heavy trailer loads, what about these odd brand service/delivery vans?
iu
Not sure what they sell for when they get turned back in off lease, but at least you'd know they've been fleet maintained. Who would work on them and what happens with insurance?
   / Truck rant. And don't know what to do. #64
When you look at their brochure, every configuration will have a tow-rating. Looks like max is now 14,000 pounds.
Also, if you wan the extra-huge fuel tank, always get a second year or later production of the truck (in F150s case, the 2019 or later) because emissions testing is only done of the first year trucks and to keep them as light as possible, the larger tank is not offered in the first year of new designs.
   / Truck rant. And don't know what to do. #65
I’m approaching crossroad with my 1985 g20 Chevrolet Van…
It is set up the way I need for my mobile work with compressor, inverter, shelves, tool boxes and racks.
180,000 on original 305 carbureted V8… replaced water pump twice, alternator and starter and cat once… otherwise no issues.
Curbside weighs in around 9,100 pounds before I add a water heater or lumber etc.
All the computer issues friends have with all their new trucks like limp home and being stranded or weeks in the shop give me pause…
MPG and ability to pull a trailer severely anemic compared to today’s offerings.
That said it seems Dodge is winning over more truck buyers.
   / Truck rant. And don't know what to do. #66
iu
Not sure what they sell for when they get turned back in off lease, but at least you'd know they've been fleet maintained. Who would work on them and what happens with insuranceis
iu
Is that not a Ford transit?
   / Truck rant. And don't know what to do. #67
Another option:
A 12 valve dodge diesel with the inline fuel pump and rebuild it with upgraded transmission, suspension parts, seats and so forth.
Don’t know how the cost would compare to a newer PU But if done properly it would make a nice drive and should last for a time.
I've got a 12V, 1994. For sure, one of the best engines ever made. Dodge trucks, however, suck. Transmissions and suspension are things that Dodge, then RAM, just failed at (though the later automatics ARE good; suspension is still sub-par- a friend bought a 2018(?) 3500 and he had a recall for a "fix" to the suspension, they were going to weld something and my friend said he'd rather got aftermarket and get a better replacement). My beef is that for the price of these things there shouldn't be ANY issues: I was looking at stuff that's pushing into the $90k range.
I'll keep my 94 as my farm truck: upgraded steering linkages/rods; dual disk and tuned IP. Dropped the idea of getting something to hook up a trailer to and go traveling: not worth the hassle and cost.
New trucks are items that are sold to folks with businesses who can "write off" some of the costs (get them for less as well).
I don't know how new trucks are but newer cars suck !
GF has a 2015 Hyundai. It burns more oil than gasoline ! I know I'm stretching it a little, but to design cars to burn 1 qt of oil per thousand miles is just unacceptable to me .
When discussing this with the service Dept. , they claim it's normal these days. said they also own the Toyota store next door and toyota specs. the same .
I have owned vehicles my entire life and never had a vehicle to burn a qt of oil between 5 K changes.
So, I did a little research on the matter, and sure enough, car makers are building engines with less tolerances, causing less friction, which results in getting better gas mileage as mandated by the government !
Burning that much oil causes other issues, it shortens sensor life and spark plug life, and who knows what else !
I have no idea what you gain by getting better fuel mileage at the expense of burning more oil !
Are newer trucks required to meet these same gasoline mileage mandates ? IDK, but it may be worth checking into before you make the purchase. I found all my info on the hyundai forums
I believe it's turbos that are the issue. Seem to recall this very thing with VW gassers. If NOT a turbo engine then that's certainly BAD. Meanwhile... my ALH TDIs might consume 1qt in 10k miles (10k oil change interval).
   / Truck rant. And don't know what to do. #68
Wrong. At least with the Ford F150, it is the non-turbo V8 that has had recalls due to excessive oil consumption. Also with the GM trucks - the V8 engines with cylinder deactivation had oil consumption problems.
   / Truck rant. And don't know what to do. #69
Every F150 from 2015 on has had the 36 gallon gas tank as an option. I have it on my 2016 and I love it. For example, with 357 miles on the odometer since the last fill-up I still have 438 miles of driving range left. That's important, out here where gas stations are few and far between.
   / Truck rant. And don't know what to do. #70
Me too.
I've been contemplating replacing my 16 year old Jeep Wrangler with a new model. But reading about all the electronic problems on the Jeep forums scares me to death. Can you imagine? Out in your Jeep, a hundred miles from pavement, and this message comes up?
Guy said the Jeep shut down and had to be towed!
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
2018 John Deere 8320RT Track Tractor (A53485)
2018 John Deere...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
(3) ROLLS OF 4' GALVANIZED FIELD FENCE (A54757)
(3) ROLLS OF 4'...
2006 FREIGHTLINER CL120 DAY CAB (A53426)
2006 FREIGHTLINER...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
