Truck Question - and quite SAFE!
   / Truck Question - and quite SAFE! #1
r0GuE
Veteran Member
West PA
ex-Bota Owner
I am purchasing a 800lb gun/fire safe. I have the pick of many freinds to borrow trucks from, and all will say yes. However, I don't want to harm their trucks. IS there any trucks not rated for such a load. The smallest is a ranger.
See.. safe! /forums/images/graemlins/laugh.gif
   / Truck Question - and quite SAFE! #2
Any of the pickups will handle 800 pounds, although that's a pretty fair load for a Ranger. This past week, I had 1350 pounds of concrete stepping stones in my Ranger, and in my opinion, that was overloaded, but I only had about 10 miles to go on streets where the speed limits were 35 and 40 mph so I had no problem.
   / Truck Question - and quite SAFE! #3
I think any actual truck would carry 800 pounds (how could it be a truck if it couldn't even carry 4 men sitting in the back?), but what I would worry about would be denting the bed. The lighter trucks are lighter all over, and the bed of the pickup might dent pretty easily, but a sheet of 3/4" plywood should distribute the weight and take any abuse from setting it down and trying to get it back out.
Cliff
   / Truck Question - and quite SAFE! #4
A gun safe is fairly tall so I would go for a full size pickup and preferably one with a headache rack give more support to keep it vertical. Also use 2" load straps.
Vernon
   / Truck Question - and quite SAFE! #5
I would not be worried about the truck. Worry about the helper to get it out of there! 100lbs/each for a large clumsy object will push it; that would be 8 people...
Once it is out of the truck, you know how to roll it on dowels or pvc, like the Egyptians moved the big rocks for the pyramids?
   / Truck Question - and quite SAFE! #6
I think any truck should handel an 800lb load,
question is how are u going to load and unload it? and get it where it needs to go? better have a few extra hands, and mabey a dolly or 2 /forums/images/graemlins/grin.gif
   / Truck Question - and quite SAFE! #7
Where did the Egyptians get PVC? /forums/images/graemlins/grin.gif
   / Truck Question - and quite SAFE! #8
I sat in a lecture in college where the speaker claimed that the ancient Egytians were the greatest metalurgist's in the world. She went on to say that there is nothing new in material science that the ancient Egyptians didn't already discover. Unfortunately, I think half the audience believed her. /forums/images/graemlins/crazy.gif
   / Truck Question - and quite SAFE! #9
Oh, I forgot to give an answer for the poster: I put a load of paver stones weighing about 1400lbs in my S-10. I knew it was over loaded, when I notice how low the tires were sitting. I put some air in them, and drove the thirty miles to get home. I don't think 800lbs should be problem at all.
   / Truck Question - and quite SAFE! #10
My gun safe was a tad over 900 lbs. and it came home in the back of my 2004 F-150. A good bit of advice for loading and unloading, set it on it's side. Something that big standing up is an accident waiting to happen in a pickup truck, raises the enter of gravity very high and it would be very easy to tip over in a turn and destroy your truck bed sides. Most place will be able to get it to your truck no problem, set it on the ground and tip the top onto the truck then get several guy to push it it. Whenever you are unloading push it out and have a few guys to drag on it and at the breakpoint wher it wants to go down just slide it out and down. ou'll end up with it leaning on the tailgate and resting on the ground, tip it up onto a dolly or cart and take it where you need to.
Mine went in a garage and where i unloaded it off the truck 3 of us drug/slid/pushed/pulled it 15' across the floor to it's new home.
What kind did ya get?
Cargo Van (A59230)
Cargo Van (A59230)
2844 (A58376)
2844 (A58376)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Chevrolet Silverado 1500 Pickup Truck (A55973)
2019 Chevrolet...
Eagle Weathervane (A55853)
Eagle Weathervane...
New Holland WorkMaster 37 (A53317)
New Holland...
