Boondox
Elite Member
- Joined
- Apr 6, 2000
- Messages
- 3,879
- Location
- Craftsbury Common, Vermont
- Tractor
- Deere 4044R cab, Kubota KX-121-3S
In the continuing saga of the 1957 Dodge pickup, I just finished replacing both wheel cylinders up front. Since there was so much rust, and so much difficulty getting replacement parts, I stripped things down to the backing plate and used that POR15 paint to reduce future corrosion. The truck looks great, but I'm a real mess. The instructions said to wear gloves, because once dry that stuff can't be removed. Figured I could be neat. Figured wrong. My hands will be gray till the top layer of skin sloughs off! Had a big gray spot on the tip of my nose, too. /w3tcompact/icons/shocked.gif Tried every chemical in the garage to no avail, and finally took a long shower and simply shaved my nose to get the paint off. /w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
But back to the truck. I have plenty of brake shoe left, and have adjusted the cams just shy of the point where the shoes rub the drum. Bled the brakes thoroughly and am getting only clear new fluid out. But the pedal goes much further down than before -- nearly to the floor -- and I can't reach the adjusting rod on the master cylinder to adjust the pedal free play. Gawd, parts of this truck are HARD to reach! Since it's my wife's truck, and we live on top of a long hill, good brakes are fairly important to me. /w3tcompact/icons/grin.gif I'm thinking of just buying a new master cylinder and having the local garage swap it out for me.
Covered in grease and loving it!
Pete
Pete
