Troybuilt wood chipper or PTO. .?
   / Troybuilt wood chipper or PTO. .? #1
cartod
Platinum Member
Northern, West Virginia
JD 4066, 1023
Are the gas wood chippers as good as a pto chipper or are they toys? Just didn't want to run tractor to chip sticks. Same with a splitter?
It's a 10hp Tecumseh motor.
   / Troybuilt wood chipper or PTO. .? #2
I have a Troybuilt 5.5hp chipper. It is not powerful enough. With a sharp blade it will chip about 8 inches of 1in+ vine maple, then you have to stop for 20-30 seconds to let the RPM's get back up, then chip another 8 inches, ect. On smaller and softer stuff it is more tolerable. It needs at least 8HP.
Bruce
   / Troybuilt wood chipper or PTO. .? #3
Not even in the same ballpark.
   / Troybuilt wood chipper or PTO. .? #4
When you say "sticks" what diameter do you mean?
I'm real happy with my pto-driven Wallenstein bx62, but it would be overkill for small stuff like yard clean-up. I use it for limbs and saplings. I can put a 20 foot long sapling in it that's 4" in diameter at the butt end and it chews right thru that sort of thing. Are you looking to just chip or chip and shred (leaves, vines, etc.)? There are some combo machines. My chipper would be worthless for shredding.
Don't have splitter, but people don't seem to have issues with the 5-8 hp gas engine driven ones. It is silly to wear out an expensive tractor if you don't have to.
Just sticks, leaves and general yard cleanup/ shredding. I just hate to put hours on a tractor for it. Wood splitters seem fine with there own little motor. I don't need to put huge limbs in.
   / Troybuilt wood chipper or PTO. .? #6
In that case I would search for the best value in a combination chipper/shredder with it's own gas engine. There are lots of choices and probably opinions here on TBN about which are better and why. If you rarely need to chip any branch over say for example, a 2" diameter, it makes cost sense to set that as a capacity limit and deal with the occasional larger pieces some other way. You don't want to spend a lot extra to do a very small percentage of your overall requirements.
Comparing flywheel weights for disc-type chippers with the same size rating is one way to judge how sturdily they are built, and more flywheel/disc weight means more energy is stored to apply to the chipping. I would also look at how easy the unit is to open up and unclog and to adjust/replace/sharpen cutting blades.
   / Troybuilt wood chipper or PTO. .? #7
When you are researching what you want to buy check to see what kind of safety mechanism is built in for the motor (shear bolt, belt system, etc). I had a MTD chipper/shredder that stalled on a knot on a 1.5-2" stick (probably birch). Anyhow, the sudden stop broke the crankshaft & split the engine block. On the bright side, gave me a reason to move up to a PTO machine! Got a good condition used Bearcat Echo for a decent price.
cheers
   / Troybuilt wood chipper or PTO. .? #8
I have a Troy Bilt chipper/shredder Chippewa style with the 10 hp. Bought it used. Put in a new chipper blade and flipped the flails to a new side. Took down 9 mature (avg 12" dia.) Poplar trees and chipped and shredded anything 3" and under. I only had one jamb due to operator overfeed and the belt took the hit.
   / Troybuilt wood chipper or PTO. .? #9
You have been lucky with your subject, I asked a question of what brand of chipper to buy and why and I get this . Go search for yourself.
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
2006 NEW HOLLAND L185 SKID STEER (A52705)
2006 NEW HOLLAND...
2007 Ford E-450 Super Duty 16ft Portable Office Truck (A54814)
2007 Ford E-450...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2019 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A52705)
2019 CATERPILLAR...
