Troybuilt junior carb spring and governor linkage
   / Troybuilt junior carb spring and governor linkage #1
Tillernoob
Troybuilt junior tiller
I have an old troybuilt junior tiller hs40-55580k it’s from the 80s I believe it won’t engage the throttle when I pull the linkage cable I believe I’m missing a spring or linkage rod off the carb! Does anyone else own one and be willing to post a pick of there carb so I can see the carb springs and governor springs and how they are attached please and thank you
   / Troybuilt junior carb spring and governor linkage #2
That is exactly what I wanted thank you. Do you know what that piece is that attaches to the throttle and the top of the governor and where I might be able to order one
   / Troybuilt junior carb spring and governor linkage #4
I helped a friend with an old Troy Built. I have no idea if this helps but maybe you can zoom in and see if it helps.
JMR 72" Root Grapple (A50121)
JMR 72" Root...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2007 Mitsubishi Fuso FE84D 16ft Dovetail Flatbed Truck (A50323)
2007 Mitsubishi...
2000 CATERPILLAR 140H MOTOR GRADER (A51406)
2000 CATERPILLAR...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
John Deere 6420 (A50120)
John Deere 6420...
