Troybilt PTO Horse
   / Troybilt PTO Horse #1
studebaker
troybilt pto horse
Reading one of the posts, the member recommended shuting off the gas valve going to the carburetor, and running remaining gas out. I bought a 1993 PTO Horse 3 years ago which had only been used one time. A technician at Tecumseh got me on to Seafoam, which I found was well worth the money, and I use it in my 2 and 4 cycle motors. The gas tank had gas in it, and the gas valve left open. I had to replace the gas line, and the gas valve at the bottom of the tank. Anyhow, the 8hp Kohler Magnum ran rough, and when I hit a rock would skip, but after using the Seafoam, which was also recommended by a repair shop, it does not skip a beat, and all of my engines run great. Check it out!
   / Troybilt PTO Horse #3
Hello & WELCOME to TractorByNet.com! :)
I have moved your thread to the Oil, Fuel, & Lubricants Forum. You'll get a better response there. ;)
   / Troybilt PTO Horse #4
Studebaker:
I read up on the Seafoam website. I've never used it before, but I have a Stihl weedeater that I may try it on.
I also have a Troybilt Horse tiller. I bought it new in 1982, and it's been great ever since. I had a choice between 8hp Tecumseh or the 8 hp Briggs. I picked the Briggs engine, as I have had good luck with them in the past.
I always use StaBil fuel stabilizer in all my small engines, as I store fuel for a year sometimes (need to use the generator after winter storms). My weedeater is acting like it has a slightly clogged fuel path. Maybe the Seafoam will fix it. Glad it worked for you!
2013 F-550 Bucket Truck (A51039)
2013 F-550 Bucket...
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
1984 Trailmobile Enclosed Van Trailer (A51039)
1984 Trailmobile...
2015 MACK GU713 (A50854)
2015 MACK GU713...
2008 John Deere 608C combine head (A50657)
2008 John Deere...
2008 FORD F-450 (A50854)
2008 FORD F-450...
