troy-super bronco
   / troy-super bronco #1
Bouoy
troy built/ bronco
I have a 05 troybilt super bronco. I been having some issues with belts popping on it the last one lasted 10 mins. I don't know if any one has a clue to what the problem is but the belt is not burnt. I will say it was real hot when I went to pick it up. any clues on a replacment or what could be the cause of this?
Thanks in advance
   / troy-super bronco #2
If you are referring to the mower deck belt, you may be missing a spring. If you look at a digram of the mower, it would be part #37 on the 42" deck.
This spring helps with the tension of the mower belt. If it is missing or replaced with the wrong spring (too strong a spring is just as bad as too weak a spring) the belt will self-destruct in short order.
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
1999 KENWORTH T800 DAY CAB (A54607)
1999 KENWORTH T800...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2022 Adams CLC-1013 Conveyor - New (A55302)
2022 Adams...
2015 KENWORTH T270 SERVICE TRUCK (A51406)
2015 KENWORTH T270...
