Troy Built tiller
   / Troy Built tiller #1
Ivan49
Lake City Mi
Kubota L 3301
I had a Troy Built tiller given to me. It is an econo horse. The motor has been replaced and does not work. I have a 5 hp motor for it and I am going to clean it up and maybe tear it apart before using it. My question is how many seals are on the transmisson and is there antrhing speical that I should check out while I have it apart. The motor needs to have a separate shaft coming out for rev so I will just set it up without reverse for now. The tines look good and the seals don't seem to be leaking on the tine end of transmission.
   / Troy Built tiller #2
Unless there is a problem with the transmission, I'd leave it alone except for maybe changing the gear oil with yellow safe gear lube.
Be careful with those seals. Some are no longer available.
2011 Chevrolet Impala 1FL Sedan (A48082)
2011 Chevrolet...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
20Yd Roll-Off Container Dumpster (A49346)
20Yd Roll-Off...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
John Deere 5055D Tractor (A48837)
John Deere 5055D...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
