Troy Built Red Horse 50 inch lawn tractor; 23 Hp Briggs V twin. Built 07
   / Troy Built Red Horse 50 inch lawn tractor; 23 Hp Briggs V twin. Built 07 #1
sr/wa
Troy Built Red Horse 2007 23HP V twin Briggs
Inherited this beast while back. Not running. Somebody{s} really abused it. Cleaned it up; put new carb., air filter, carb. to govenor link with associated springs on it.
Problem: Will start & run 1 second with the choke pulled out....has gotten a little better, will run bout 5 seconds. Have had the carb. off several times. Every thing seems good. Have checked the solenoid, it works. Have adjusted governor several times. It's getting fuel, but apparently not enuf or steady.
What am I missing???
   / Troy Built Red Horse 50 inch lawn tractor; 23 Hp Briggs V twin. Built 07 #2
You need compression spark and fuel. Have you confirmed there is a good spark and adequate compression?
2019 FREIGHTLINER M2106 DEBRIS BUCKET TRUCK (A51406)
2019 FREIGHTLINER...
2008 FORD F450 SERVICE TRUCK (A54607)
2008 FORD F450...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A54815)
2008 KZ Sportsman...
2005 GMC C8500 CHASSIS TRUCK (A54756)
2005 GMC C8500...
RGN Heavy Haul Trailer (A52377)
RGN Heavy Haul...
