troy bilt cub rzt 50
   / troy bilt cub rzt 50 #1
65cobra
Well I heard this unit had some bad reviews. But I really like it
I have a 20 hp 46 inch deck craftsman mower and It kept plugging up and throwing belts and giving me other issues. The other day I was at lowes and they had a returned/repaired troy bilt rzt 50 for only $1450 regularily $2600 they said the guy didn't have it more than two months and ran over something while mowing and sheered a spindle. Well I couldn't pass it up.
This thing is sooo much better easily cut my time in half (even though I am still learning to drive it.) It powered through stuff the previous tractor would of choked on and it did it at 2/3 throttle. I was mowing pretty wet grass and did plug it a couple of times but the discharge shoot is twice as big and it throws the clippings out with a lot more energy. The old mower would of needed cleaning several times, I probably would of had to give up.
It does peel out a bit so it will take some practice wet ground didn't help any. It also had some attachment on the front with some balast bolted on I removed that I think it should help.
I can't speak for the long term yet but so far this thing is 10 times better than the older rider. Its also the first ZTR I have driven so I can only compare it to a rider. Backing up is still tricky seems like I have to hold one lever further than the other one. Btw my yard is just over a 1/2 acre of grass but its divided into 5 sections. So the ZTR really helps on the last bit of each section that took a lot of circling with the rider.
   / troy bilt cub rzt 50 #2
Now that you've taken the ballast off of the front, you may need wheelie bars on the rear. Sounds like you got a deal.
Used it again today I think it cut my time down to 1/3 :) works much better without the weights, maybe the PO needed it for a bagger setup.
Bull Skull (A55758)
Bull Skull (A55758)
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
Portable Restroom (A54865)
Portable Restroom...
2017 Jeep Grand Cherokee SUV (A55853)
2017 Jeep Grand...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50324)
2015 Clarke Power...
