"Troy Bilt" 27 ton log splitter, add winch? (Not 20 ton. Helps to know your own equipment)
   / "Troy Bilt" 27 ton log splitter, add winch? (Not 20 ton. Helps to know your own equipment) #11
I've seen V8 car engines picked up with boat trailer winches.
I'll ask the obvious question...Why not use a hydraulic log loader? I put one on my splitter and it lifts 24" long logs, some of which are over 30" in diameter, without effort. Plus it makes a nice "table" to place smaller stuff on so it is easy to reach to load into the splitter.
You already have the hydraulics, so all that is needed is a valve, a relatively small cylinder, and some fabrication to make the lift.
What really helped my back was adding some trailer jacks to my splitter this year that allow me to raise the entire splitter up to a more comfortable operating height. Because the loader does the heavy lifting it doesn't matter that the splitting table is 3 feet off of the ground.
Don't know what a hydraulic log loader is, but will give it a search. Mean time, if you have some examples, it would help me get a clue.
   / "Troy Bilt" 27 ton log splitter, add winch? (Not 20 ton. Helps to know your own equipment) #13
Usually a hydraulic lift that is hinged on main beam of splitter and when in lowered position is on ground but when raised to allows log to roll into alignment with splitter ram...
One variation as in video below...
I found this one also that uses no additional hydraulic components. Food for thought.
   / "Troy Bilt" 27 ton log splitter, add winch? (Not 20 ton. Helps to know your own equipment) #16
   / "Troy Bilt" 27 ton log splitter, add winch? (Not 20 ton. Helps to know your own equipment) #17
This thread might be some good reading for you.
   / "Troy Bilt" 27 ton log splitter, add winch? (Not 20 ton. Helps to know your own equipment) #18
There is a link in that thread to a guy from NZ who made a simple frame using the return on his splitter to lift logs. Seems so simple that I wonder why manufacturers don't just build that into their splitters.
For the sake of discussion, this Norwood skid winch for tractor log skidding looks interesting. I don't know enough about winches to say anything useful other than after seeing a winch used with the tree service chipper, it got my attention. https://www.norwoodsawmills.com/skid-winch-hydraulic-log-skidding-winch
   / "Troy Bilt" 27 ton log splitter, add winch? (Not 20 ton. Helps to know your own equipment) #19
My guess is that your 20 ton splitter is mostly used in the vertical position and you are looking for easier ways to move the cut “rounds” up to the splitter. Guessing you don’t have a grapple or method using your front end loader to move the rounds. Could you mount a 12 volt winch on the 3 pt hitch of your tractor to drag the rounds up towards the splitter?
   / "Troy Bilt" 27 ton log splitter, add winch? (Not 20 ton. Helps to know your own equipment) #20
Got a 20 Ton Troy Bilt log splitter, Honda engine, that runs well. Getting more painful to bend and lift and got a lot of wood to split as I clear a wooded area.
While I can tilt the splitter to vertical was thinking to add a hydraulic winch to help drag/lift log sections. Most I have found here so far is about dragging large logs uphill or get machinery unstuck. And most hydraulic winches I've seen are way too big and expensive for my needs.
Ideas?
I built a large stainless steel "tray" and attached it to my splitter opposite the 'operator position'. Then I'd load up my bucket and place it just beyond the edge of the tray. (just in case it did creep down) As you remove and split wood you can leave a little on the tray and create a space in the bucket for the wood you just split. When the bucket load is split it is already back in the bucket ready for transport to the wood pile.
Allied 760 Loader (A50515)
Allied 760 Loader...
2004 Caterpillar 345B Hydraulic Excavator (A50322)
2004 Caterpillar...
Portable Cattle Loading Shute (A50515)
Portable Cattle...
Deutz-Allis GVL Poly Corn Head (A50514)
Deutz-Allis GVL...
UNUSED KIVEL SKID STEER QUICK ATTACH PALLET FORKS (A51244)
UNUSED KIVEL SKID...
