Troubleshoot a 7 pin snowblower
   / Troubleshoot a 7 pin snowblower #11
one thing with a voltmeter it may read the voltage bur drop when a load is attached, thats why we use the bulb, you can get a 12 volt bulb with pigtails from any auto parts shop (not LED style) I can not recall the connector, got it from Bobcat dealer but anything that will allow contact with the factory harness connection
I'm not an expert but here is what I know about the 7 pin:
Yes, the 7 pin setup operates off of a CAN bus system (and is one of the reasons bobcat attachments are so expensive, b/c you need a controller to interpret the CAN bus signals vs something like a 14 pin connector that just fires 12v). On the machine side, you can test for 12v on the big pins at the machine connection to see if your controller on that side has 12v. Doesn't mean that controller is necessarily working but eliminates 1 possibility. You'll need an oscilloscope to read the digital signals on the smaller pins AND I'm not sure about that as I've never done it. If you look at your attachment, say a snowblower, the 7 pin on the attachment plugs into the machine and then it goes to a controller/control box. That controller is all sealed up and converts the CAN bus signals into 12v for the solenoids. Therefore after the controller can you test for 12v with the machine powered on (doesn't need to be running) and someone pressing the appropriate switch/button.
In this case it worked (I had 12v after the control box on the attachment) and then it didn't. I'll head over there tomorrow grab a few pictures and see what we can figure out. Again, I suspect either a bad connection at the 7pin, fault in the harness or possibly a dying controller on the attachment itself. But I'm not sure if a controller would work and then not.
   / Troubleshoot a 7 pin snowblower #13
what I would do in this situation as above verify the 12v supply and use the cable ground, using a light verify output at the solinoids and thats where I would load the machine up and visit the dealer, they can easily use there machine to run the snowblower thro a few cycles and if they have a blower in the rental check the machine on there blower, had to do this with a Vee plow and my S590
my dealer is good helping me that way, also a rental shop could try the blower for you, that control box on the attachment can be checked with the dealer software but they will charge you for that service
Long story short (after switching attachments on different machines, etc) turns out the attachment side 7pin had a loose connection. Thanks for all of the suggestions.
2019 Toyota Rav4 AWD SUV (A55853)
2019 Toyota Rav4...
2012 Dodge Journey SUV (A53424)
2012 Dodge Journey...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
