Trouble with starting B7800
   / Trouble with starting B7800 #1
kastaway
Glenwillow, Ohio
Kubota
B7800 will not start. It is either the clutch safety switch of the ignition switch. How can I find out which. I can hold clutch in and either work the ignition switch or just hold it and finally will turn over. If it is the clutch switch, how can I get to it.
   / Trouble with starting B7800 #2
The clutch switch is usually on the outside of the transmision, on the clutch linkage somewhere. The switches are cheap. It's easier to replace them than it is to bypass them to see if they're bad. From your description it sounds like the ignition switch is having problems.
I am almost positive its the ignition as you said. We pushed in clutch, turned key and help, then tapped with a hammer and it wanted to start. Must be bad ignition switch. Thanks so much.
2018 Chevrolet Tahoe SUV (A50324)
2018 Chevrolet...
Snapper Pro Zero Turn Mower (A48837)
Snapper Pro Zero...
Char-Griller BBQ PIT (A50860)
Char-Griller BBQ...
Adams Conveyor (A50397)
Adams Conveyor...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A50459)
KNOW BEFORE YOU...
2018 CATERPILLAR CB7 DBL DRUM ROLLER (A50458)
2018 CATERPILLAR...
