trouble starting new 1046
   / trouble starting new 1046 #11
Whether the problem is weak spark or bad fuel delivery, the starter fluid will help it start. The fact that it keeps running and also will start the next day makes me think your fuel delivery is OK.
I'm no mechanical genius either, I tend to fight my way through these problems, but you can usually isolate it with a bit of playing like I suggested. Fordlords mentioned the fuel shutdown solenoid, could it be failing or have a bad connection? Maybe the points need to be replaced?
I think if you stick with it you'll solve this problem, be patient and try a few things and report back what you see.
   / trouble starting new 1046 #12
Call Kohler direct; tell them your story and I bet you will get it taken care of.
By Phone:
Customer service is available to take your call 24 hours a day, seven days a week.
Call us toll-free at: 800.544.2444
Thanks for all the tips. I will work on it this weekend and definitely call Kohler customer service. By the way, don't ya'll think the dealer should have been willing to tear the carb apart to perhaps locate the problem instead of wanting to charge me? Unless I've been living on Mars for the past few years, I always thought a warranty was what I consider "peace of mind insurance" that the product will perform correctly during that period or the manufacturer will fix/repair at no cost to the consumer. Anyway, that is why I really can't bring it back to the dealer.....I really think I would shove his head into the carb.
   / trouble starting new 1046 #14
I agree with you. A few years ago I thought I had a transmission problem on the 1211, we were planning to replace the tractor that year. I called my dealer and he told me to bring it in. When I said I was worried about spending much money on it he said "bring it in, lets see whats wrong, I'll let you know what it will cost to fix it. If you don't want to fix it I won't charge you." That's a dealer that isn't afraid of spending an hour of labor to help out a long time customer.
So, I think your dealer should have offered to take another look at it. When in your first post you mentioned that the dealer couldn't find anything wrong, it sent up a red flag for me. I doubt your problem is too difficult to find, the dealer's mechanic should identify it in a half hour. Just my opinion.
   / trouble starting new 1046 #15
re the "Tiny Tach" - That one on Ebay was listed at $42.
I got a tach from Briggs & Stratton that was simply a coil of spring-steel wire that you reel out of a hub until it resonates with the engine. Then read the rpm on a scale. It works well and matches readings with the tachometers in my car and tractor.
If Harbor Freight sold something that simple it would be under $5. At B&S it should still be under $15.
But like another poster said, just adjust it down where it still can gain rpm easily. This isn't rocket science.
   / trouble starting new 1046 #16
05tundra said:
I'm very disappointed in Cub Cadet/Kohler. My 1046 is approaching 2yrs of age and has 26 hours on the engine. After 7-10 days of non use, it won't start. The worst part about this, is that it started doing this within a few months after purchase. The engine will turn over until the battery is dead, but it won't start. The only way I can start it, is to spray a shot of carb cleaner in the carb throat. When I did take it back to the dealer, they couldn't find anything wrong with it. I wanted them to clean the carb but they said "cleaning the carb" wasn't under warranty and would charge me 30-40 dollars. I can't take it back to the dealer again because I am afraid that I will choke the manager. I've been running stabil in my fuel the whole time. Any ideas on what might be causing this? Thanks,
Dump the fuel and start with fresh stuff from the station without stabalizer. This will eliminate "old" fuel as the problem. If the dealer let the tractor warm up first, it may have just started right up. This is not an unknown fuel characteristic of stale fuel. Second, if there is still a problem, remove the fuel bowl and inspect/clean the rubber coated fuel needle tip. They have a tendency to stick sometimes. If its neither of these, then proceed to the suggestions of others.
charlie in vt
   / trouble starting new 1046 #17
This brings to mind something. I have not used Stabil with any of my small engines, preferring to shut the fuel valve off and run the carb dry, then just dumping the old fuel in the tank. I once tried Stabil with a Kawasaki motorcycle, and had nothing but problems getting it to start and run after sitting. I now know that Kohler engines use the same make Keihin carbs as that Kawasaki, and they might not care for Stabil too much. -Fordlords-
   / trouble starting new 1046 #18
Same here. I've never used a fuel stabilizer, even in my generators or boat engines. I run the carbs out and dump the tanks. I fog the $$$ boat 2-strokes as they are running out of fuel.
Joel
   / trouble starting new 1046 #19
Uh Oh, not a stabilizer/no stabilizer thread :eek: :eek: :eek:
05tundra, let us know if you have any luck this weekend.
   / trouble starting new 1046 #20
pegleg said:
I have the 1046 CC that is only one mowing season old. I have not experienced your problem as of yet anyhow. My problem is it runs to high on idle and the dealer says if it is touched it will void my warranty. I would love to get my hands on a tach that will do 2 cylinder engines to check what it is set at, at the factory. There is hardly any difference between idle and full throttle. :)
Pegleg,
On the Kohler twins when you go to shut them down, let them idle a few minutes to cool, then go wide-open throttle and turn the key off. This is what my IH dealer recomended, and it works fine. (It's got something to do with the government mandated emmission controls on that engine.)
Doc
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2007 PETERBILT 379 TANDEM AXLE SLEEPER TRUCK (A53426)
2007 PETERBILT 379...
HEAVY DUTY JACK (A54757)
HEAVY DUTY JACK...
