Trouble Starting After Head Gasket Replacement
   / Trouble Starting After Head Gasket Replacement #1
allengentry
Virginia
Yanmar F13D
Engine started and ran fine before tear down, now it won't start.
Full fuel tank.
New fuel filter, bowl, and o-ring fully saturated and primed.
Primed at the injector pump.
Cracked open hard lines and bled at the pump 3-5 times.
Cracked open the lines at the injector and bled what seems like 10-12 times.
Set valves at .008.
Double checked valves were at .008.
Still won't start, spit or sputter.
Engine is getting fuel. Exhaust manifold is moist inside, where as it was dry before tear down.
Little puffs of blue while cranking.
Have not tried ether. See no reason to and really don't want to.
Ideas?
Frustrated because it ran well before.....
   / Trouble Starting After Head Gasket Replacement #2
I don't know if it is the problem, but I never use ether in a diesel. If you have to use something use WD-40.
It works.
Good Luck
   / Trouble Starting After Head Gasket Replacement #3
Did you run a compression test after changing the headgasket? Could it be a timming issue? I would double check the cam shaft timming. If you had the injection pump out I would also check it's timming also.
   / Trouble Starting After Head Gasket Replacement #4
If you are sure its in time and getting fuel, roll it down a hill and release the clutch or tow it with a truck to get engine cranking rpm up. This gets you compression and temperature in the cylinders and it will begin to run (hopefully). Use the glow plugs even though its not 'cold' outside.
Pulled it behind my Jeep and it started right up.
Thanks.
   / Trouble Starting After Head Gasket Replacement #6
That's good news. You might now check the battery and cables. With its 'new' compression levels, the starter current and voltage demands are up. A dead cell in the battery, weak post contact or frayed cable will continue to give you grief. It might have been happy with 15:1 compression but now with 23, the starting rpm is down.
A new battery and cables are most certainly in order. Bad battery and corroded cables.....
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2018 INTERNATIONAL 4400 SBA 4X2 SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2011 Ford F-150...
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
