Trouble finding RH tierod for 2005 kubota L2800 DT
   / Trouble finding RH tierod for 2005 kubota L2800 DT #1
clovergamecock
Clover SC
Kubota L2800 4WD FEL
   / Trouble finding RH tierod for 2005 kubota L2800 DT #3
Suggestions???
Wade
Call your dealer. No way to know if the prices you see online, are a good deal or not, without first knowing what your dealer would charge you.
Kubota parts are pretty hard to come by in the aftermarket. Lots of dealer only stuff. And when you do find stuff on ebay, it is usually either a dealer selling parts (which prices would be similar to your local dealer), or someone who ordered wrong parts and no longer needs (better prices, but not as common as dealers selling parts online).
As to the tierod....what is broke? Do you need the whole "assembly"?, or just the rod? or just one of the ball joints?
Same with the fuel cap? whats wrong with it?
I had to replace the fuel cap on my L3400. Top cracked and "pushed" out where the fuel tank pushes against the seal when tightening. The tighter you tightened the cap, the more it pushed the crack open. There were two different caps they used, so you will need to know your serial number to make sure you get the right one. Mine was the larger cap, at some point in time they went to a smaller cap.
The whole assembly is broken and the tierod ends are worn out. Grease fittings are completely rotted. So I need all of it.
The fuel cap lip is busted.
Chicken Coop (A50121)
2017 Peterbilt 348 T/A Rolloff Truck (A51692)
2017 Peterbilt 348...
2012 International 4300 Reefer Truck (A52748)
2012 International...
2022 Ford F-550 Cab and Chassis Truck (A50323)
2022 Ford F-550...
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
