Trouble baling
/ Trouble baling #1
Manitoulin
Wikwemikong
kubota M7040
I'm baling hay with a John Deere Sileage Special 456, however, my Kubota 7040 after baling for a couple of hours, just looses power to the point where it just stalls and then won't start again, requires a boost, why would this be happening? Tractor is only a year and half years old. Noticed earlier, the kicker for baler wouldn't work or only work for about the first six or seven round bales. Not what the heck is going on, maybe under powered for the Baler?
/ Trouble baling #2
Welcome to TBN
When you state your tractor looses power do you mean fuel or electrical? From viewing JD parts it appears 456 has bale ramp with it's own hyd circuit not push bar similar to larger JD balers.
/ Trouble baling
Electrical, the tractor just shuts and die's out, won't start unless it is boosted after it cools down.
/ Trouble baling #4
Have you tested to determine if alternator is charging? I'd suggest to clean/tighten all four battery cable connections. You could have battery load tested.
2005 SBX-5 Box Blade Tractor Attachment (A61572)
2005 SBX-5 Box...
2017 Nissan Sentra Sedan (A64557)
2017 Nissan Sentra...
2022 EZ-GO ELITE...
2012 PREMIER 4NNT PORTABLE PUMP (A63276)
2012 PREMIER 4NNT...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
2025 Auger Drill Bit Skid Steer Attachment (A64553)
2025 Auger Drill...
