Triple solenoid valve
/ Triple solenoid valve #21
Brian ,thanks for the pictures ,I have looked at those valves many times and couldn't understand how it gave the multiplier effect .
/ Triple solenoid valve #24
Brian - when you stack the valves you recommend, how do they seal between units. Do you need to order special parts. Also to plum in, would I run hoses from the one set of original remotes - say the A-B circuit on my unit to the Lt side of the block (or do hard lines)?
I cant thank you enough for your explanation. Now I actually understand how this works.
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2013 FORD F250 (A60460)
2013 FORD F250...
LILLISTON 2R ROLLING CULTIVATOR (A63291)
LILLISTON 2R...
Freightliner Cascadia (A63689)
Freightliner...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2022 EZ-GO ELITE...
