Triple Rinsing
/ Triple Rinsing #1
Jstpssng
Epic Contributor
Maine
Kubota L3301
This is a two part post, first questions about managing your equipment;
What do you do with the material while rinsing your spray tank whether it's backpack, 3 pth, or bigger? Does anybody use the same tank for different materials, such as switching from insecticide to herbicide or vice versa? I try to avoid pesticides as much as I can and confess that I've always just used one for materials to spray on my food crops, and another for the one time that I used Roundup about 3 years ago; and never rinsed them afterwards.
Now for a rant;
It's the Roundup sprayer that I'm thinking about using for potato beetles, which are denuding my vines. My el cheapo hand sprayer finally disintegrated so I bought a new one at the salvage/discount store. (AKA Marden's, for anybody familiar with Maine.) When I went to use it though I discovered that it already had liquid residue in it; I filled it and walked down the gravel road sprinkling it out, then dribbled the dregs on a burdock plant. 3 hours later there are spots on the leaves where the droplets landed... and I still need to spray the Spinosad, although it's getting past the point where it matters.
I also wish that I had left what ever the residue was in the sprayer... as I just publicly confessed to spreading whatever it is onto a public road.
/ Triple Rinsing #3
My pet peeve is that every weed/garden sprayer should have a filter. I must have ten of the things with different stuff. Never had a backpack sprayer.
/ Triple Rinsing
I just dilute with water and dump it out on my driveway.
I think that might be the best way, but wasn't sure. Like a dumba** I forgot that I had the Roundup sprayer, and bought another when I went down to my mother's to treat the invasives which have been taking over the old hayfield, so now I have two herbicide sprayers. Do you switch back and forth between herbicides and insecticides?
My last one was just a 2 quart hand sprayer that I had for 10 years or more. I am going to upgrade to something IC powered though as my fruit trees will need it. The two I have for Roundup are 2 gallon units, the only backpack sprayer I've ever used was for stump treating when I was doing powerline maintenance. We also used mist blowers, which covered a lot of ground fast. Then there was the time that I got to work on a helicopter spray project... I was on the ground but it was still fun. :thumbsup:
/ Triple Rinsing #5
I have separate sprayers for different chemicals. Dont trust the rinse. And yes filters are about mandatory.
/ Triple Rinsing #6
I have one 2 gallon sprayer and 1 fifteen gallon electric boom/wand sprayer. I use them both for many different things. I try and mix just enough or even a little less product for that day's use so there isn't much left at the end. If its just plant fertilizer, I have no worries about just rinsing and spraying a few time to clear it. If I'm using insecticide, like liquid seven, for example, I pour off any left over product into clean marked jugs for reuse later. Then I triple rinse by filling and spraying three times on my rocky drive, around the base of the woodpile, or a brush pile that's been here and grown for 25 years. Its diluted by thousands of times and its being applied to places I don't want insects anyway. No chance of getting into the water supply in those areas on our place either. I do the same with weed and brush killers.
As I mentioned, I try and mix up only as much product as I can use at the time. Less waste and more diluted at cleanup time.
/ Triple Rinsing #7
I mix up what I think I will use in 1 of 5 sprayers. There is a 25 gallon boom sprayer and 4 garden sprayers from 1 to 2 gallons. Each has a different use. When it is empty, I put about a gallon of water in it, pump it up and let it discharge into the gravel driveway. The roundup sprayer especially. It turns into a gooey mess and the tip plugs if not emptied and rinsed out.
/ Triple Rinsing #8
I have a sprayer - 25 gallon tank and a pump that is PTO driven. I haven't used it in over twenty five years. So it may no longer function.
It has a "mixing" feature. You can direct the water in the tank - thru the pump and back into the tank. Bypassing the spray wand. I used RoundUP and some type of fruit tree spray(s) in it. When I finished spraying - fill the tank with ten gallons of water - let it "mix" for a while - spray the contents on the gravel driveway. I would do this three times. Never had any problems with residual RoundUP damaging any fruit trees.
/ Triple Rinsing #9
So is mine but one, I use it quite often and two, mine as 400 gallon. I mix what I use and try to use it all and I wash out with Dawn dishwash detergent (fill the tank about 1/3 full) and spray it inside with the accessory spray wand), dump that and rinse 2 times with clean clear water. Used to use that expensive Nutra-Sol but found out dawn works just as good for a lot cheaper.
I spray everything from Rounbdup Ultra Max on roundup ready beans to 2-4D to Lasso to liquified 46% urea.
/ Triple Rinsing #10
Here’s the “proper” way to clean your tank. http://www.agphd.com/wp-content/uploads/2015/05/SPRAYER-TANK-CLEANOUT.pdf
When a commercial cleaner is recommended, I use this: FarmWorks Spray Tank Cleaner, 2 lb., 7531 at Tractor Supply Co..
Might be overkill, but I’d rather not nuke my soil for a year.
These new Chaplin mix on exit are intriguing. Separate tanks for different chemicals makes for much easier rinsing (just the hose and wand/boom). No need to rinse/neutralize the water or chemical tanks. Chapin Mixes On Exit ATV Sprayer, 25 gal., 97562 at Tractor Supply Co.
/ Triple Rinsing #11
Maybe be proper in Colorado but I don't have the time to waste letting cleaning solution lay in the spray tank for 8 hours. Put in my Dawn, fill 1/3 full, turn on the agitation, spritz the inside well, drain and rinse twice. been doing it that way for oh, 25 years now and never had a crop damage issue. I will say the grass in the center of the driveway is brown though.:laughing:
/ Triple Rinsing
At least it cuts down on your mowing time. ;)
/ Triple Rinsing #13
I just use the same sprayer for everything. I've always just rinsed with water. Most of what I use is round up. I guess if I was spraying food that I would eat out of a garden I might worry about getting a separate sprayer.
/ Triple Rinsing #15
/ Triple Rinsing #17
I pull a 500 gal pto sprayer with round up or malathion, copper, or manzate.
When Im done I always rinse it with hot water. I used to spray 2000 gals in a day, but we downsized, know Im down to 500, but I still use the same method of cleaning the sprayer.
/ Triple Rinsing
I used to use it but Dawn is much cheaper and like I said, the grass strip in my farm drive is always brown,
Dawn is useful for a lot of things. I keep a watered down bottle in my truck for washing my hands. I've even heard of people using it to do their dishes!
I don't dare read the label though as I'm sure that it must cause cancer in California.
You use the same sprayer for both though, so must be cleaning it well. What do you do with the residue?
/ Triple Rinsing #19
With hot hot water, after 50 gals its clean, its an air blast sprayer, and I remove the jets and soak them too.
2003 Honda Pilot AWD SUV (A66738)
2003 Honda Pilot...
QA Mini Grapple (A64912)
QA Mini Grapple...
2014 Ford Escape SUV (A66738)
2014 Ford Escape...
SDlanch SSL60 (A64912)
2021 HLA 48in. Hydraulic Root Rake Grapple Attachment (A66734)
2021 HLA 48in...
2022 WEILER S450 SKIDDER (A65056)
2022 WEILER S450...
