Snow Equipment Owning/Operating Trip springs on snow plow were too stiff
   / Trip springs on snow plow were too stiff #1
Chuck4310
Central NH
JD 4310 ePowerReverser
Solved this problem. My Curtis plow came with 4 springs. Way overkill for me.
I'd be plowing along and inevitably hit something and POW, it would practically throw me out of the seat!
Well, after I removed 2 of them it's better.
There is also a hydraulic relief device mounted on the plow. Does anyone know how it functions? Are they adjustable?
   / Trip springs on snow plow were too stiff #2
The relief valve is called a "crossover relief valve" or "cushion valve". It's purpose is to protect the blade and framework by allowing the blade to move if it hits a immovable object. Say the blade is angled full left-so the right side is furthermost forward...and you hit a curb with the right side-the relief will trip allowing the fluid to escape the right cylinder so the blade will straighten out.
They are usually adjustable-but I would not mess with it...
Clear as mud?
   / Trip springs on snow plow were too stiff #3
My 6 1/2' Curtis came with only 2 springs. Trip works very well for my size tractor.
The hydraulic relief valve also works very well. But has no adjustment.
kennyd- I've hit objects with the blade angled and I don't think the relief device operated. The tractor sometimes shudders to a stop and the blade is still angled. It doesn't happen often, but I plow rough uneven ground.
It's almost like I would like to see the relief operate sooner than put the stress on the loader frame. That's why I removed two of the trip springs.
I guess my question is how do I know that the device works and is it set at a point that will protect the structure of the plow?
ronjhall- Mine is a 6 1/2' also but came with 4 springs. How can you tell that the hydraulic relief valve is working? Mine is a small rectangular block mounted on the plow.
Chuck
   / Trip springs on snow plow were too stiff #5
Chuck, Why not call Curtis and ask them what it's set for?
   / Trip springs on snow plow were too stiff #6
Probably has to be set stiff so it doesn't go into relief when pushing heavy snow load. I think it's there more to protect against serious damage, not to make comfortable stops when hitting stationary objects.
As far as the 4 springs, it does seem overkill and those springs don't look wimpy, 8' fisher plows only have 2 springs.
But you could have unloaded them with the threaded adjusters, they look cranked down pretty tight, don't know if that would have softened it enough though.
JB.
This is what happens with no relief valve,
   / Trip springs on snow plow were too stiff #7
Chuck
The blade changes angle position. The trip works before relief valve. I have a rock at end of my drive. It is high enough that trip does not work. But angle will change when blade catches it at speed. It depends on conditions. If I have little weight on front wheels tractor will slide sideways before tripping relief valve. Happens most often when blade is not angled.
   / Trip springs on snow plow were too stiff #8
I picked up the Curtis 6 1/2 plow this year, and it was manual. Curtis wanted $700.00 for the kit to convert it to power angle. I picked up 2 cylinders, hoses, and a cushion valve for under $300. Took me 10 minutes to install. The cushion valve has a preset PSI. Generally around 2500 to 3000. The place I bought the valve asked if I wanted to beef it up to 3000, but I wanted the lower PSI to protect the tractor. I have had the trip springs work a couple of times, but I have not hit anything to trigger the valve yet. Here is a pic of the hookup.
JB- I agree that the relief valve must be set higher than the trip springs to protect the tractor. It just seems that mine has taken some serious hits in a way that didn't cause the trip springs to work and I never noticed the blade change angle as if the relief valve operated.
The springs may not look it but they are slightly loose. Any looser and the blade would flop foreward.
Is the picture your plow? How did that happen?
ronj- This may be what is happening. The impact is sending the tractor off to one side due to the slippery conditions and lighter front end.
NHbot- Yours looks very similar to mine including the position of the relief valve. Yours looks permanently mounted. No quick connect?
kennyd- I may just call them and get the scoop.
Thanks for the comments guys. :)
Chuck
   / Trip springs on snow plow were too stiff #10
Chuck
Yeah, after looking at the picture I see the springs aren't stretched at all, in which case if it trips to easy with just the 2 springs you can tighten those 2 up a little.
That's not my plow, I saw it at the JD dealer, they were trying to sell it cheap as is, looks like it hit something HARD. It's made by Horst Welding, which is the same company that makes my pallet forks, looks like it's well made.
JB.
17801 (A51694)
17801 (A51694)
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2022 CASE 580 SUPER N BACKHOE (A51246)
2022 CASE 580...
John Deere 5090E Tractor with Loader Prep Package, 2 Rear Remotes, Warranty Until 2028 (A52748)
John Deere 5090E...
2011 FORD F-650 ROUSTABOUT TRUCK (A52472)
2011 FORD F-650...
