Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ?
   / Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ? #1
LuckyPierre
TDY Mass
BX22
I bought a BXpanded brush guard for my BX22, BXP also states it fits BX-1500, 1800, 1830, 2200, X23. I set up correctly but per instructions, well it doesn't even come close to fitting. Pamplet states it "mounts in seconds". I double checked my order/invoice, I have the correct model KBXUA3.
I installed the BXP 2 hanger bolts that the brush guard front arms rest on. When I tried to fit the rear quick attachments tabs that fix to the mower deck quick disconnect I found the two rear holes on the BxPed were 1/1/2 to 2" too long making it impossible to mount without a lot of cutting and fabricating. I'm certain the front bolts are installed correctly.
   / Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ? #2
Tried to find a photo, but it doesn't show one for a BX22.
BX22
Bruce
   / Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ? #4
OK. Under Armor, not brush guard.
This is what I was looking for.
I have their Under Armor on my BX2360 and it fits OK.
Can you post some photos of the problem?
Bruce
Your BX2360 calls for a different UA model #. I posted the BX models my UA fit in my first post. Have pictures will post soon.
   / Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ? #6
It's news to me that they make one for the older models at all. Far as I know, anything older than the 60 series you had to go with Bro-Tek.
BXpanded 'under armor' photo
my first attempt a uploading...you should be able get an idea of the mismatch
   / Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ? #9
It's been about 5 years since I put mine on, but I think I had to install it with the deck lift arms lowered, then raise it and keep it up. I don't have a mid-mount mower, so it was a one-time installation.
Bruce
   / Tried installing a new BXpanded brush guard...Mounts in seconds no way. Anyone else ? #10
I know you said your invoice shows the correct model, however that doesn't necessarily mean you actually have the correct part.
I would recommend you contact BXpanded & check measurements against what you have as to what the model KBXUA3 should be.
My under armor is for a BX24 & fits perfectly & takes only a few minutes to install or remove.
32in. Tilt Grading Bucket Mini Excavator Attachment (A59228)
32in. Tilt Grading...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
2023 BOBCAT E50 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E50...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
Toyota RF1-SD1X45 4,500 LB Stand-On Electric Forklift (A59228)
Toyota RF1-SD1X45...
2007 Caterpillar 262C Compact Wheel Loader Skid Steer (A59228)
2007 Caterpillar...
