Tricks running Kubota RA 1035 rotary rake
   / Tricks running Kubota RA 1035 rotary rake #1
powerscol
SW Colorado
CT 235
Cold and wet outside today so read my new rake manual front to back and sideways. I think I understand the basics o height (just into the uncut hay - no ground contact. etc) However I figure folks have learned before me. Could anyone be willing to share what they have learned running their single rotary rakes? Thanks for any help.
Fields are relative flat - a few dips here and there and the occasional gofer mound. Tractor is a Bobcat CT 235. Rake is at the upper weight limit, but can lift easily (some hydraulics groan). Ill need to go slow in transport mode.
This replaces an old ford 503 side delivery model - any learning curve?
   / Tricks running Kubota RA 1035 rotary rake #2
Main thing I hated with a mounted rotary is you have to lift it "all the time" to make turns versus the classic pull type side delivery where all you have to do is steer.
Main tip I have is to rake in straight lines as much as possible.
2nd tip is make sure your front end is weighed right unless you want to drive on the rear tires and steer with brakes...
You may or may not be able to lift the rake high enough to clear a finished windrow on your tractor, one of the main advantages of 3pt.
It is a 3pt mounted rotary rake and it appears I can lift it high enough. With the hydraulic top link I have I can get extra lift if needed.
   / Tricks running Kubota RA 1035 rotary rake #4
Beware of obstructions. The arms are designed to bend if they hit a fence or trough etc to save the rest of the rake.
How quick does the machine stop? On a twin rotor Claas rake a hit will bend 3 arms minimum before stopping. Make sure you have several spare arms as Inexperienced operators WILL bend arms adjusting to the machine. Also expect bent arms at the begining of each season to.
One thing that can cause frustration is when the hay has been cut with a very short stubble, giving the effect of needles (alfalfa). This holds the hay to the ground like it is glued down and leaves a rough finish. There is nothing you can do at that point. Just make sure the mower operator knows you want a 2" stubble.
The ideal stubble length is 2", it is long enough to bend when the hay is raked.
A rotary rake will give a very even consistant row that lets you shovel the hay into the baler without breaking shear bolts.
By adjusting the rotor speed you can change the shape of the row. This becomes very important when making round bales.
Happy raking.
(5) JOHN DEERE WEIGHTS & MOUNT (A52708)
(5) JOHN DEERE...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt GPI Pump (A59076)
LOT: Fuel Transfer...
2017 Ford F-550 4x4 DurALift DTAXS39 39ft. Bucket Truck (A55973)
2017 Ford F-550...
2014 REITNOUER MAXIMISER 48' FLATBED TRAILER (A58018)
2014 REITNOUER...
LOT: (2) Kimball Midwest 4-Drawer Hardware Cabinets, (1) 2-Drawer Hardware Cabinet w/Contents & (A59076)
LOT: (2) Kimball...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
