Trickling water in winter
   / Trickling water in winter #1
TristanDickey
1967 Ford Something
Never had the honor of worrying about freezing pipes until recently. I've got a submersible pump on my well. its housed almost two feet underground and stuffed with insulation. the house connection has heat tape and insulation. Should i trickle my water to keep from freezing? i dont want to burn out my well pump leaving the water running all the time.
   / Trickling water in winter #2
Without your location filled in your profile... the best we can do is guess... If you are in Florida, You are go to go!
On the other hand, if you are near the Canada border... turn your pump off!!!
What temperature are you worried about? If it's above freezing, you *should* be fine... (you get the point...)
   / Trickling water in winter #3
What part(s) of your system are most vulnerable?
Can you use a lamps* on exposed parts?...tenting a lamp with a towel works good for protecting outside valves etc...
[edit]
*Not using LED bulbs
in arkansas. supposed to be in the 20s tonight and maybe 30 all day tomorrow
[edit]
its all encased 2 feet under the dirt surround by cinderblocks stuffed with insulation. its not necessarily 'exposed' we had -30 degrees a week before christmas and yeah one piece of pvc cracked.
   / Trickling water in winter #6
If that's all it's going to be you should be good. Going forward, hay bales, styrofoam or anything to provide a little extra insulation is helpful to keep it from freezing.
   / Trickling water in winter #7
[edit]
Pretty funny, Just did a repair because of LED lamps not putting off any heat.
   / Trickling water in winter #8
Not sure what you mean. The all-time record low in Arkansas is -29 and that was in 1905. If that was a wind chill, ignore it for things like pipes.
Source:Wind Chill Questions
Can wind chill impact my car's radiator or exposed water pipe?
The only effect wind chill has on inanimate objects, such as car radiators and water pipes, is to shorten the amount of time for the object to cool. The inanimate object will not cool below the actual air temperature. For example, if the temperature outside is -5°F and the wind chill temperature is -31°F, then your car's radiator will not drop lower than -5°F.
wind chill doesnt effect pipes freezing? we got a lot of wind today and tomorrow too. not sure if that hurts or not.
   / Trickling water in winter #10
No, wind chill just affects animals. As @Torvy posted, wind can cool a pipe faster, but wind can't cool it below the air temperature.
I would point out that wearing wind proof clothing negates the effect of wind chill on humans, except for exposed areas like eyes and perhaps cheeks.
Your pump should be goo; lots of good advice above.
All the best,
Peter
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
3 Point 36'' Lay Off Three Rows Plow (A51573)
3 Point 36'' Lay...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A52748)
2012 KINZE FLAT...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
