trick to bh removal
   / trick to bh removal #11
</font><font color="blue" class="small">( Keep your fingers crossed for me. G )</font>
Just to be clear about it, once you have adjusted the BH to remove and you have moved forward out of the supports, turn OFF the tractor, and then move the BH controls to different positions to relieve the pressure. Disconnect the hoses and drive off. I suggest that you drop the BH itself onto something with the outriggers/stabilizers down and out to support side-to-side, and then to relieve the pressure you can lift the stabilizers a little, which will allow the BH assembly to rest down on the support you placed it on. By doing that, you will also be relieving the pressure. To hook up again, back the tractor STRAIGHT in until you can easily rehook the hoses, lift the stabilizers and adjust the bucket until they are lined up with the supports, back into the subframe, lock in the pins and go dig up China. John
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
2016 Ford F-350 Super Duty Pickup Truck, VIN: 1FT8W3DT1GEB84319, Crew Cab, 4x4, Steel Flatbed (A59076)
2016 Ford F-350...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2016 KENWORTH T660 SLEEPER TRUCK (A58214)
2016 KENWORTH T660...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58018)
2019 FREIGHTLINER...
LOT: (3) Water Meters, (2) Valves (A59076)
LOT: (3) Water...
