Trenching with the BX, backhoe question.
/ Trenching with the BX, backhoe question. #1
Mcaveman
Maryland
Own Z121S, BX25 purchased w 35 hrs
So I trenched in a silt fence for my big project at my house and found it very annoying that every time I had to move tractor forward I had to reverse seat or it would stall, am I doing something wrong or can that be disabled?
Thanks in advance
/ Trenching with the BX, backhoe question. #2
Don't for sure but there's some sort of interlock at the seat, maybe a bypass wire to defeat that interlock will help.
Another thought, why not use the BH to drag the tractor along, pickup the FEL and the outriggers and extend the BH pull the tractor, you should be able to do that from the Reversed position and direct the tractor with the steering wheel.
Just thinking out loud.
/ Trenching with the BX, backhoe question. #3
I think the OP wants to move the BX forward, not backward... but maybe still could be accomplished by leaving the speed select in neutral and using the hoe to PUSH the tractor forward.
To the OP, no you're not doing anything wrong... same thing happens to me. I recall a thread on here s few years ago about someone who rigged up a hand control linked to the forward/reverse treadle, with a momentary push button on it to defeat the seat switch. With this he could move the tractor from his seated position at the backhoe controls. He mounted this hand control in the vacant slot above the 3pt lift lever to the right of the seat. No great detail was given on how this linkage was accomplished. Perhaps a search will find this thread.
Pete
/ Trenching with the BX, backhoe question. #5
Thanks in advance
Its normal. Kubota doesnt want you moving the tractor forward or backward from the backhoe position. You can try pushing forward using the hoe with the parking brake off and the stabs lifted.
There is a safety switch you can bypass so you can reach down and lift the direction pedal from the rear seat.
/ Trenching with the BX, backhoe question. #6
Unless they've done something new and inventive to the newer BX-25's, just leave your gear selector in neutral, raise your outriggers, raise your front bucket, and push/pull to where you want to be.
Mine is a 2012 and works just fine, exactly like any Case, Cat, or JCB I've ever used. Good luck and let us know.
George
/ Trenching with the BX, backhoe question. #7
I'm able to trench with my BX-25 in gear. However, there is a trick. First, always try and work with gravity--head downhill. When you push the hst pedal, you have to finesse it, giving little pushes. If you give too much pressure, too quickly, it will stall. Maybe they fine tuned your tractor so that you can't do this. But I can do it on mine.
/ Trenching with the BX, backhoe question. #8
Had much the same problem on my B and solved it by using a wire tie to keep the switch from opening and stalling the tractor. This also helped as I now can reverse my seat and move my tractor or sometimes I just climb over the seat and stand to move the tractor after I have lifted the stabs and FEL. By "fixing" the seat switch I am not bothered by the motor trying to shutdown if I hit a bump while driving. I appreciate Kubota's concern for my safety but in the long run I will decide what risks are acceptable to me. Also by using a wire tie I can easily put the machine back in original condition if I ever were to trade up (I wish) for a cab model with a heater!
/ Trenching with the BX, backhoe question. #9
I turn in my seat (instead of turning the seat) most of the time when I use the BH for small projects. I've also used the release brake, lift FEL and legs and push with bucket method for longer jobs.
/ Trenching with the BX, backhoe question. #10
I dont set my BX parking brakes on when trenching and leave it in neutral. On level ground I just turn and raise fel a little and push with BH a couple feet and lower FEL again and back to work. On level ground I had to reposition the BX a couple times and I didnt want to bother with turning the seat then lock in so I just stand on the lower platform and press the 2 safety interlocks and steer with the other hand and move BX for front end on different angle. Otherwise I dont need to raise the fel at all and can glide forward when on a slight downhill after raising outriggers slightly off ground.
Only once- just once , there was a only way to trench was up a steep hill so I just locked horns with a larger tractor with his/my FEL since his bucket was wider then mine, I put my bucket inside his and chained it together. I would motion to him to pull me /stop when needed.
/ Trenching with the BX, backhoe question. #11
George
Yes!!
/ Trenching with the BX, backhoe question. #12
Be extremely careful moving it downhill while in neutral, there is a dangerous risk of it rolling off out of control! I don't have that interlock on my B21 and I have done the reach over and push down the pedal to move it. I always keep it in gear for the braking!
/ Trenching with the BX, backhoe question. #13
I guess I cheat and not so safe but often when I am trenching with my BX I often leave the seat facing forward and use the BH on my knees. I get real tired and quick of turning the seat to move the machine. The risk is throwing yourself out of the seat or bumping your head on the ROPS (I have LEDs mounted on the ROPS) especially if you have the RPMs high and then the BH gets 'jerky'. :shocked:
Thanks for all the replies, I have some good ideas to try now. I will try to push/pull it with the hoe.
/ Trenching with the BX, backhoe question. #15
I have even placed my tractor back over a open trench from the side by placing the front bucket over the trench and using the hoe to lift and swing the tractor back over the trench.
Go on you-tube and watch some of the back-hoe tricks on there. It is amazing what a good operator can do with one.
/ Trenching with the BX, backhoe question. #16
same here for small jobs
/ Trenching with the BX, backhoe question. #17
I have a piece of 1 in pvc pipe . I just reach over , raise the bucket a bit and push on the pedal with the pipe .
/ Trenching with the BX, backhoe question. #18
Same idea here but just use a old broom stick (I did bypass my seat switch however)
/ Trenching with the BX, backhoe question. #19
This! This is what I've done as well. Was going to post it, but AStanton beat me to it.
How do you bypass the seat safety switch?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 ISUZU NPR CAB AND CHASSIS (A60736)
2021 ISUZU NPR CAB...
2019 Autocar ACX Xpeditor T/A Heil 31Yd Side Loader Garbage Truck (A61568)
2019 Autocar ACX...
2011 DOOSAN G25KW GENERATOR (A58214)
2011 DOOSAN G25KW...
2013 CATERPILLAR 336E L (A58214)
2013 CATERPILLAR...
