Backhoe Trenching Bucket (and possibly ripping tooth)
   / Trenching Bucket (and possibly ripping tooth) #1
StevenInOlympia
Olympia, WA
LS XR3135H
I'm trying to source a trenching bucket and possibly a ripping tooth for my LB2100 backhoe. I've searched the forums and found a reference to Bro-Tek but they have informed me they are not making anything due to COVID and have absolutely no ETA on when they will resume. I've also contacted my local guys and they can't find a source either. Any leads? I'm just looking to bury conduit. Thanks.
   / Trenching Bucket (and possibly ripping tooth) #2
YouTube
This could work for direct bury wire. Plastic pipe? Don't know about your local electrical codes.
   / Trenching Bucket (and possibly ripping tooth) #3
Michigan Iron & Equipment makes some pretty skookum Rippers.
   / Trenching Bucket (and possibly ripping tooth) #4
You could just bury conduit use a sub soiler , i have ran water lines and electric service up to over 300 ft by blocking the pipe end digging a starting hole and making multi passes before connecting pipe for pull.They also make a attachment for the sub soiler this. You don’t really need the contraption the u tube guy is building for his sub soiler.
   / Trenching Bucket (and possibly ripping tooth) #5
We built a sub soiler when I was a 'kid' (maybe 15). We called it a ripper, heavy duty. We ran 2in pvc pipe through our pasture by capping the end with an eye bolt drilled into it, hooking a small chain to the eye and around the tooth of the ripper (which only had one tooth installed in the center) and dragging it through the dirt. Drive it forward until the end gets to about the start, glue on the next pipe and signal the drive to drive forward another 20 feet or so. We did about 20 acres this way. If the pipe broke or we hit a rock, then we would dig it up and repair, start again. It was awesome and still in use today!
Where the sprinklers came up, before we drug the pipe though the ground, we bored holes at each sprinkler location, if memory serves, 4in holes using an auger. Drug the pipe though the holes, cut the pipe to install a T with the part going up threaded, sleeved the hole with 2in pipe and back fill the little bit around it, threaded in metal 1in risers. It was something like that. We wanted the ability to remove the risers for mowing, which I dont think we ever did as we just mowed around them one or twice a year. System works(ed) very well. Simply turn a valve at the buried main line and turn an entire line on. Come back that night and turn it off, move up or down one line and turn that one on. Irrigation was easy.
But I digress, we used a sub-soiler to pull small pipe through the ground very easily. We didnt trench the line first, just drug it down.
   / Trenching Bucket (and possibly ripping tooth) #6
I would never run electric wire in the ground without it being in conduit. Every time i make a water line or electric line run i make a map of it location only problem when i need it i cant find the map my file cabinet eats them. i then have to go to the old stand by of using dowsing rod to help find the line.
2002 Bobcat 763 Compact Skid Steer (A56435)
2002 Bobcat 763...
CAT D5G LGP DOZER (A58214)
CAT D5G LGP DOZER...
1999 International F-4900 T/A Cab and Chassis Truck (A56858)
1999 International...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2012 PROCO KILL TRAILER (A58214)
2012 PROCO KILL...
2012 TEX MEX TRAILER LOW BOY GOOSENECK (A58214)
2012 TEX MEX...
