Trenching - Backhoe or Sub-soiler?
   / Trenching - Backhoe or Sub-soiler? #11
The subsoiler is fine if you're pulling a single cable, if you want conduit or multiple cables, I'd looking a vibratory plow or a trencher.
If you want to do it yourself, then the backhoe is the way to go.
   / Trenching - Backhoe or Sub-soiler? #12
Backhoe is the way to go, and as you said you already have one, nice clean trench for your electric service. That's the way I'd go.
Devildog
   / Trenching - Backhoe or Sub-soiler? #13
100' isn't that far especially if you already have the backhoe.
   / Trenching - Backhoe or Sub-soiler? #14
Backhoe. You didn't say if the wire is in conduit or not, but 2' down will be easiest with backhoe. Also, would you want to put other things in the trench such as water or conduit for low voltage? Yes to either question makes the 12" backhoe the only clean way to go.
I've put in a lot of AC, low voltage, and water around my place and always used my 12" bucket on the backhoe. All cable is in conduit. No worries about damaging the cable (rocks or groundhogs), less worries about lightning damage. Put a tape at around 1' deep. If you ever have to cross a cable, you can dig, find the tape, and then use a shovel - you'll run into conduit and not the wire itself. I tend to go down to 2.5' (a little overkill).
Pete
   / Trenching - Backhoe or Sub-soiler? #15
A few years ago I rented a trencher for an A/C line for a pool, It cost me about
$400 for the day, I had to go about 150' it took about 1 1/2 hours to trench the 150' and had to go down 24" in one pass.
I had about 45 min. drive to the rental place to pick it up had to fill it back up with gas and then take it back. Then drive home.
Now that i have a tractor with a backhoe I would just use the backhoe and save the $400 for a new attachment.
Hey thanks for the responses Gents. Mark - thanks for the link. Since I've already got the 'hoe, and time is a big factor, I'll just use the hoe....my first real job with it....thanks again!
   / Trenching - Backhoe or Sub-soiler? #17
I would definately go with the backhoe and don't worry about it being 1 foot wide. Go with a wider bucket so you can get down in there and lay the conduit on a groomed flat bottom.
Some of my trenches were required to be 5 1/2 feet deep for the main power feed and over three feet for water piping. There were also patches of various sized rocks that the backhoe was able to deal with by either working around or digging them out. Now, I think I've dug about 600' of trench. It's fun having tractor time.
   / Trenching - Backhoe or Sub-soiler? #18
If a 1' bucket is all you have, go for it. I have both 1' and 18" buckets and would use the larger one.
It is sometimes hard to empty my 1' bucket with moist clay or other types of soil I have. I never know when I am going to have to get down and chisel out the bucket. I use the 18" one almost all the time, and very seldom have a problem with it.
BTW, the best method is to put all of the spoils on the uphill side of the trench. I had read this but never understood why until I tried picking up a large rock and placing it downhill from the machine. The machine can get pretty tippy if you try to place anything too far downhill in a side-slope situation.
   / Trenching - Backhoe or Sub-soiler? #19
If you have little experience with the backhoe I would suggest you pick a spot on the bucket that is about two feet above the bucket teeth to use as a visual guage of the depth you need. Try to focus on making the trench smooth on bottom without waves in it. Digging long trenches like this one are great for developing your backhoe skills. Use a flat shovel to smooth the bottom out prior to laying in your line. You know your operating skills are improving when there is very little that needs smoothing with the shovel.:D
Good advice, sir, thanks! I will make a big visible mark or note a particular point on the bucket at least 2' up. I actually have 3 buckets, a 3', 2', and I BELIEVE a 12", but might be a 16"....I'll have to go see here soon. Won't get around to the project for awhile, but looking forward to it!
2017 JLG Skytrak 6036 6,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG Skytrak...
John Deere Gator XUV835M 4x4 Utility Cart (A48082)
John Deere Gator...
2019 CATERPILLAR D6N LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
UNUSED CFG Industrial MX15RX Mini Excavator (A47384)
UNUSED CFG...
