trenching attachment advice
   / trenching attachment advice #1
Bristol Fashion
bcs 737
Hiya, we're a csa here in Bristol, using a venerable bcs 737. Is anyone aware of an attachment that can dig a narrow trench suitable for burying 20mm black water pipe, ie narrow and around 30cm deep?
   / trenching attachment advice #2
   / trenching attachment advice #3
other option would be to use the rotary plow since you only need it under the surface.
   / trenching attachment advice #4
I've rented a self propelled walk behind trencher numerous times, it did a trench 6"x18" at over 100' feet per hour, in hard rocky ground. Take small 6" bites, (multiple passes). Well under $100/day.
   / trenching attachment advice #5
When I worked for Bell Telephone, we used a vibratory plow instead of a trencher. We used it to install black water pipe for later use as conduit for underground wiring.
Unlike a trencher, the plow made very little surface damage. On most jobs, you couldn't tell any work was done.
Many rental yards have them at reasonable rates. Unless you do a lot of work like this, it might be cheaper to rent rather than buy an attachment.
  • Good Post
Reactions: JJT
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
toro turf sweeper (A50324)
toro turf sweeper...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Morooka MST 660VD Tracked Dump Truck (A52128)
Morooka MST 660VD...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
