dave1949
Super Star Member
I have crossed some wet areas by digging the trench with my backhoe attachment and piling the dirt in a track wider than the tractor ahead of the direction I wanted to go. If it is dry enough to drive on without getting stuck, I keep going. If it is too wet, I leave it to dry out enough to drive on and then resume.
You may have to do it in stages like that with a wheeled tractor. Once you get the swale dug out, it should work to dry out the area in general, which would allow you to go back in and remove the dirt you piled up to drive on. If it does not dry up the area, you need a Plan B
. It takes a long time for a pile of saturated dirt to dry out, especially if it has grass and weeds in it. Patience is needed.
A tracked excavator of decent size can deal with some amazing mud if there is firmer dirt up to 24-30 inches below the surface muck. That can often be the case.
