Dirt Moving Trench Attachment
   / Trench Attachment #1
Madison, Ga
Kubota L3200HST with LA524 Loader, Quick Connect; Loaded R4 Tires
I'm burying a small black poly irrigation water line about 12" deep. I had a fellow with a skid steer do some other work and he just attached what looked like an 18" or so spike to his loader and made the narrow trench I needed. I now find I have to extend that line. Do they make something similar that my Kubota L3200HST could use? Can someone point me in the right direction?
Thanks!
   / Trench Attachment #2
A subsoiler is what I used to bury poly pipe a foot or so deep years ago.
   / Trench Attachment #3
I have a subsoiler but never used it in that fashion, although I hear many others have. My former L3200 pulled it at over a foot down. You have to pull the pipe through the ground attached to the subsoiler or feed the pipe through a guide to the bottom of the subsoiler. A subsoiler wont create an open trench you can place pipe into. Personally I'd run the subsoiler through the ground at least once to loosen stuff up first if I tried either of those options.
I have a 3pt trencher that does 3', but it wasn't that cheap even used. Low low on my L4060 with HST+ will go slow enough but it's a lot of effort to go that slow & steady. A regular HST could probably do it, but it would be a lot of concentration.
   / Trench Attachment #4
I made a couple of runs with the subsoiler, laid the well pipe, then tamped it into the trench to a somewhat uniform depth. Finished up by running the tractor over the trench a few times, and it closed right up. My water pipe was not mission critical as far as depth. It's just a 200' water line for the garden, with a 10' drop over 200', so it's easy to drain before winter.
I've seen home made subsoilers for wire that feed into the trench via a short section of curved PVC pipe... Looks like they get the wire right to the bottom of the trench.
2013 Ford Transit Connect Cargo Van (A55852)
2013 Ford Transit...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
SULLIVAN PATEK AIR COMPRESSOR (A55745)
SULLIVAN PATEK AIR...
2015 Liebherr L542 Articulated Wheel Loader (A55851)
2015 Liebherr L542...
