Sprayer Tree Sprayers
   / Tree Sprayers
Thanks for the note on the electric pressure washing working with a header tank- I could not try that as I don't have a tank I can use that way. I even considered drilling a hole in the bucked and mounting a fitting, and just putting water in the bucket. :)
I'll give it a shot that way the next time I can, and see how it goes.
   / Tree Sprayers #22
I have an electric Stihl pressure washer that is used to spray trees, grass, flowers, etc. Never had a problem with the system or pump. Since its electric, I take it out on the road or fields by hooking on my tractor powered PTO alternator and put a 150 gallon solution tank in the front end loader bucket. Plug it in, feed it with a hose from the tank, raise the bucket to get some head pressure and bingo, a tree sprayer, a weed sprayer, a mosquito sprayer and a remote car washer. I even used it a few times to spray a mist on the horses. They loved it during hot August days. Set the spray wand to wide pattern and that's all I ever need. Wash out with clear water.
How much vertical height are you able to get with that setup?
   / Tree Sprayers
I did end up hooking up my pressure washer with the sprayer tank as a feed tank. I ran some tests comparing the big spray gun from Northern Tool and the standard wand. The spray gun gave me control of droplet size, from a very fine mist to a stream. In stream mode it sprayed higher too, so I like that setup best.
In fine mist mode it put out a lot of mist- I was thinking that if I was spraying trees, it would be at least 10x faster than using the wand on my standard sprayer.
I can easily hit the peaks of my roof, so about 30' high with that setup.
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
2004 IC Corporation 3000IC School Bus (A55852)
2004 IC...
2014 PETERBILT 388 VACUUM TRUCK (A55745)
2014 PETERBILT 388...
1996 Timpte 46ft Hopper (A55315)
1996 Timpte 46ft...
2020 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A55973)
2020 Caterpillar...
Frontier FM2015 (A53314)
Frontier FM2015...
