tree shear owners
   / tree shear owners #11
looking forward to your input in case you build your own ... but in any case keep us posted ..... thanks and good luck
   / tree shear owners
Neal
Thanks for the response and the great pictures!
I have been looking at the photos for a few days and I have a few more questions:
1. What is the thickness of the plates that hold the blades?
2. What is the thickness of the blades?
3. What is the dia of the pins/bolts? 1"?
4. What is the thickness of the pipe that hold the cutting head?
5. Have you noticed any wear on the pins? Is there a way to grease them?
6. What keeps the blades, plates, and cylinder 'square'? Because everything moves on 4 pins, it seems like it would rotate into a parallelogram instead of staying square as the blades close. See attached picture.
Thanks
Tim
   / tree shear owners
I called the manufacturer today. They do have a web site it is:
<A target="_blank" HREF=http://www.precisionmfg.com/>http://www.precisionmfg.com/</A>
   / tree shear owners #14
Tim,
Plates that hold blades are 2ea 4x4x1/2 angle iron welded back to back, then center 8" between the pressure plates is another 1/2" flat plate to make a total of 1"
Blades are 3/4" thick with 2x1/2 welded on outer edge.
The Pins/Bolts are 1-1/4"
I can not see the end of the pipe without taking unit apart, but the blade points stick out 36" past the past pivot point of the power tilt & I have not done any damage yet, so I would expect it was at least schedule 80 if not solid. It is 2-3/8 outside dia so may be pipe.
I have not noticed any wear on the pins so far. and there are no grease points.
The main frame made from 4x4 angles & other metal is attached to the pipe so it stays straight across. The pins go through this, so they can not move. There are outter & inner stops to the blades so neither can go past wide open or center when closing. One blade can move without the other, only till the pressure is equalized when cutting. The tires on the tractor will give this much to let the cutter push sideways up to 4".
   / tree shear owners
Well, I finally got a tree shear built. I decided to build one similar to the tree shear Neal owns. I was able to save quite a bit of money by building it myself. See attached pictures.
I gave it a test run of about 20 cedar trees last night. It seems to work very well. It may not be much faster than cutting them with a chainsaw, but it sure is a lot less work (and even a little fun). Especially when you have hundreds or possibly thousands of little trees to remove.
I purchased most of the metal new, except for the skid steer mounting plate. I had enough scrap metal to build that. Instead of having custom blades machined, I used 3/4" x 8" cutting edge. I also added a removable expanded mesh screen to the skid steer mount to protect the operator from branches. The frame of the screen slides into the 2 vertical pieces of tubing on the front of the mount. I am not a very good welder. So I cut most of the metal and tack welded it together and then hired a local welder to weld the important stress areas with 'good' welds.
I still want to add a cylinder to rotate the blades 90° for cutting branches off. But, I didn't want to spend any more money on it until I am confident my version of the shear works well. Also, I will need a hydraulic selector valve because my skid steer only has one remote.
In order to save some money, I decided to use a 4"x8" cylinder instead of the 5"x8" used by Precision Mfg. I left enough room in the design that I can easily replace the 4x8 with a 5x8 if I want some more shearing power. I am not sure if the blades made of cutting edge would take the extra force without bending. Precision Mfg uses T1 steel which I think is stronger than standard cutting edge steel. Currently, it will still shear a 6" cedar tree in one clip, but that is its max. The hydraulic relief value starts to open when doing a 6" tree. If shearing a hardwood tree I am sure its max would be a smaller tree.
Neal, thanks for all of your help and the great pictures. Your help is greatly appreciated!
   / tree shear owners
Another picture with blades closed.
   / tree shear owners
Picture with screen attached before the shear was painted.
   / tree shear owners #19
Great looking job. Hope it does everything you want it to.
Just curious, why do you not push them out with your deere?
I don't know anything about cedar, as do they come back out after being cut off.
I was wondering if you have seen or could use the treegetters on tbn. I built mine after seeing one and like it a lot for smaller trees that are a little to large to brushhog easily. I like to keep the brush hog on for counter balance when using it, then after pulling the trees up & lay them on the ground, just brush hog the tops & maybe the roots. This leaves pretty much, just a straight trunk to load & hall off. Takes up less space on the truck & puts a lot of mulch back on the ground.
If interested, search for "cleaning the fence row is fun now" or hear is a link to one picture. <A target="_blank" HREF=http://www.tractorbynet.com/forumfiles/5-133011-Treegetterhangson.JPG> click here</A>
   / tree shear owners
Neal
Cedars don't grow back, unless you miss one branch near the ground. That branch will eventually grow up into a tree. Cedars reproduce very quickly by their seeds. In our area they grow just about anywhere.
I have pushed them out with the JD crawler, but it doesn't work as well as you would think. It is pretty time consuming. The small cedars (2" or less) are too 'rubbery', the trees just bend down and the dozer blade slides right over the top of them. You back up and they stand right back up again. 3 to 4" ones push out fairly well. Put the blade up high and push to expose some of the root, back up and push under the root ball. Larger than than 4" you spend a lot of time digging around them so that you can get under some of the root ball. Luckily cedars like most evergreens have a small root ball. A larger dozer would work well if you didn't mind pushing a lot of the grass and dirt out with them.
I had seen your treegetter post and have considered them also. But, wasn't sure if it would work for my usage. I would want to be sure it worked with cedars in our type of soil before spending the time and money to build one(looks like a lot of welding went into yours). There is a lot of clay around here. After seeing other shears in our area in action and talking with you, the shear seemed like it would definately work. It does seem to work well and it is much faster than pushing with my dozer.
The problems I wondered about on the treegetter.
1. Cedars have a lot of taper and bend fairly easily when pushed against. They may be 4" at the stump, but .5" at chest height. I am afraid it may just slide up the tree. Although angling it down into the root like you have suggested may eliminate that problem.
2. My skid steer doesn't have much lift capacity(600lb operating, 1200lb tipping load), so I don't think it would pull them out of the ground. My NH TC45D can lift 2000lbs so it would probably work, but I don't have a quick attach on it. So removing the bucket with grapple would be time consuming. 3pt would be an option.
3. The treegetter would have a max diameter of 3 or 4" tree. Just guessing by your pictures.
I like your idea of brush hogging the tree once it is laying down. I will have to give that a try.
A treegetter may be a future project, but for now the shear is a giant improvement over the other removal methods I have tried.
2013 Dodge Journey SE SUV (A55853)
2013 Dodge Journey...
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A57193)
UNUSED...
AGT SAII100 SKID STEER QUICK ATTACH 48" (A57193)
AGT SAII100 SKID...
2012 Ford Fusion Sedan (A55853)
2012 Ford Fusion...
2019 MACK PINNACLE (A55745)
2019 MACK PINNACLE...
UNUSED FUTURE FT-X39 39" HYD TRENCHER (A57193)
UNUSED FUTURE...
