Tree Shear for a Kubota B21?
   / Tree Shear for a Kubota B21? #1
sparkkky
Oklahoma
Kubota B21
Hello, looking for a tree shear lite enough to mount on a B21?
   / Tree Shear for a Kubota B21? #2
Try Power-trac.com then select new.
J.J. those look like they are made for just their tractors.
   / Tree Shear for a Kubota B21? #5
I don't think you'll find anything light enough for a B21, but this company states they have the lightest tree shear avaiable. There isn't much info on the website, but you may contact them to find out more. Here's the link http://www.midlandindustrialgroup.com/aamain.html
John
Thanks for the links going to call on the Lil Snip tomorrow. Found two more and the one I like best is by Vassar right here in Oklahoma, double cylinder seven inch tree in one bite, replaces FEL bucket and weights 660lbs.
   / Tree Shear for a Kubota B21? #7
</font><font color="blue" class="small">(
)</font>
You found links and didn't share them with us? Shame shame shame. John /forums/images/graemlins/grin.gif
EDIT: I found the vassar link, but I also found the exact same equipment on China Depot I wonder if these are imported and touted as being FROM Oklahoma? This site states the #3 shear tractor mount is 700#. I don't see why it wouldn't work on my CK20 even though they state minimum of 30HP. I have the hydro flow and pressure, and the loader can sure lift that weight. John
   / Tree Shear for a Kubota B21? #8
Guys, this isn't to anyone person. Has anyone thought about how much a tree weighs? If it isn't cut clear with the first pass for one reason or another, it has a very good chance of taking your small tractors over with it. Think about it, all that weight going to one side without being cut clear. There is a real good chance that it could tip you over or even it it is cut clear, what if it comes over on you? I know for one, that I don't want to hear that someone was killed with one of these things.
   / Tree Shear for a Kubota B21? #9
</font><font color="blue" class="small">( Guys, this isn't to anyone person. Has anyone thought about how much a tree weighs? If it isn't cut clear with the first pass for one reason or another, it has a very good chance of taking your small tractors over with it. Think about it, all that weight going to one side without being cut clear. There is a real good chance that it could tip you over or even it it is cut clear, what if it comes over on you? I know for one, that I don't want to hear that someone was killed with one of these things. )</font>
Jerry
You said just what I was thinking. Trees routinely lift my 9500# TN. They would probably throw a tiny B21.
Andy
   / Tree Shear for a Kubota B21? #10
I'm just afraid that someone will wind up getting hurt. I have a 40 horsepower tractor that is quite a bit larger than a BX and have really been debating making a shear for it. If I do, it will just be for scrub brush up to 3 inches or so.
Toro Zero Turn Mower (A50324)
Toro Zero Turn...
2004 Sterling L8500 4,000 Gallon T/A Water Truck (A50323)
2004 Sterling...
2013 PETERBILT 367 DAY CAB (INOPERABLE) (A50854)
2013 PETERBILT 367...
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2023 PETERBILT 579...
2015 INTERNATIONAL 4300 26 FT NON CDL BOX TRUCK (A51219)
2015 INTERNATIONAL...
