Tree felling directional question
   / Tree felling directional question #31
Bark, nut, and leaves all look like walnut to me
   / Tree felling directional question #32
Cut a stem open, and google "walnut pith" it's the only pith like it... chambered.
   / Tree felling directional question #33
I didn't read all the posts. Did anybody mentioned wind effect? Friend of mine told me that they hooked up a pickup to pull tree in certain direction (coincidentally against wind) when they cut the tree it fell in wind direction and threw the pickup like a rag doll.
   / Tree felling directional question #34
That sounds like more wind than I'd cut a tree in.
   / Tree felling directional question #35
And here is an Empty nut shell from last fall that I found lying on the ground, obviously without the green husk on it.
Ok got it this time
   / Tree felling directional question #36
This is a valid concern Ladia. It can make a difference with a tree with the crown intact. Depending on the size tree, a 15-20 mph wind can be enough to exert out ward force. Not so much for a topped tree and just a stem drop. The problem lies in the gusts. A 10 mph steady wind can gust up to 35 mph. Subsequent gusts can be higher the more mph.
Of course you know the gusts will come just at the wrong time.
   / Tree felling directional question #40
I know a guy who uses his pickup to aid in felling trees. To me that just seems ridiculous. Pickups, even 4x4s just don't have much pull when they're on soft ground and hitched to something up high. I could see maybe if you had mud tires, and a heavy load in the bed, and you ran the rope through a block so you weren't reducing the weight on the tires by pulling something up high, then maybe it would be effective. For larger trees, though it seems like a good way to get your truck pulled all over the place while felling a tree the wrong way.
2014 Ford F-150 Pickup Truck (A53422)
2014 Ford F-150...
2009 Chevrolet C8500 Dump Truck, VIN # 1GBT8C4B59F409922 (A54865)
2009 Chevrolet...
MISC CABINETS FLOORING (A54757)
MISC CABINETS...
LOAD OUT AND SHIPPING (A54865)
LOAD OUT AND...
1990 KME (A53424)
1990 KME (A53424)
