Tredal Pedal Hard To Push!
   / Tredal Pedal Hard To Push! #11
Wow, good to know it's that easy to split our tractors. In case I need a clutch someday or something.
   / Tredal Pedal Hard To Push! #12
It's harder to do a clutch.
The hst model can come apart in the middle close to where you sit.
If you need a clutch you have to split it forward at the engine/bellhousing joint.
More stuff to move there.
Aligning the clutch isn't bad on a single clutch tractor(hst).
Dual clutches are a little tougher.....
BTI
   / Tredal Pedal Hard To Push! #13
NY_kioti_sales said:
no not a last resort, it is a final fix. Then you don't mess with it anymore. And its not really that hard of a job.
I agree i have broke tractors apart before. And the ck series os no where as bad as the bigger machines i have broke down. Its just you will need to have access to a shop for this kind of repair. Its not something you do in your back yard.
   / Tredal Pedal Hard To Push! #14
talked to my dealer today and this is a known issue with Kioit and it is a repair free of charge if you take the tractor to the dealer with this issue. I have scheduled mine to be repaired. It is a recal type thing but not exactly that.
   / Tredal Pedal Hard To Push! #15
It it not a recall, it is a update for those who are having a problem with a sticky pedal. Many of these units have no problems at all with the pedal and do not need this update.
   / Tredal Pedal Hard To Push! #16
Sounds like what people in the auto industry call a Technical Service Bulletin (TSB). Not a recall, but a common enough issue where the manufacturer will repair the issue under the warranty.
   / Tredal Pedal Hard To Push! #17
I heard from a reputable dealer that the issue seems to occur mostly in tractors left outside. Not sure if that is exclusively a problem of tractors that get wet however. I had a 2004 CK20 that I kept in a barn and never had a sticky pedal problem.
   / Tredal Pedal Hard To Push! #18
Yeah like i said it isnt exactly a recall. As far as keeping it in the shed out of the rain, mine has never been in the rain since i have owned it that i can recall. Like the other guy said it isnt all of them either and it is only on tractors amde before 2006 i think he told me. After that they were putting the new parts in. I did find out that the labor would be covered by my dealer so i guess kioti will not cover the labor just the parts from the way he talked. In any case the tractor is in the shop now. This would be the only thing that has been wrong witht the tractor since i got it and i dont really consider it a major issue. I have done things with that little tractor that some cant do with about a 40 HP 2wd machine and it has never checked up or complained. I have already started talking to my dealler about a DK 55.
WACKER NEUSON RTSC3 TRENCH COMPACTOR (A52709)
WACKER NEUSON...
2012 International ProStar T/A Day Cab Truck Tractor (A56858)
2012 International...
1995 ADVA Concrete Mixer TRUCK (A56858)
1995 ADVA Concrete...
MOBILE BBQ GRILL (A52708)
MOBILE BBQ GRILL...
J-BAR 4' ROATRY MOWER (A52708)
J-BAR 4' ROATRY...
2020 Big Tex 22GN25T5 30' Gooseneck Trailer, VIN: 16V6X2528L6050344, Tandem Axle, Wood Deck, Bad (A59076)
2020 Big Tex...
