Treating diesel in north Texas winters
   / Treating diesel in north Texas winters #31
When I lived in Wisconsin I never had to
treat the #2 diesel as it was treated at the
pump. Also the Temps were 30 to 35 degrees
below zero and never had any problems with
gelling.
Here in West Texas very seldom get any gelling
temps but I use the white bottle to treat the
#2 diesel year round so no problems.
willy
   / Treating diesel in north Texas winters #32
Which is why you have to take care of yourselves...
The offroad diesel here ULSD...supposedly not good for the valve seats (inadequate upper cylinder lubricity is what I've read). That probably applies to older tractors, but I figure Power Service is a lot cheaper than an engine overhaul.
It does get cold enough for diesel to gell, especially considering most tractors set idle quite a bit and most, including mine, are outside.
I've been told by several "reliable" people that clear diesel and red diesel are the same product with a dye added to red.
   / Treating diesel in north Texas winters #33
I think it also depends on the equipment, the mechanical s, and the filter media. Some of the newer equipment have finer filter media that is more prone to plugging once the fuel reaches the cloud point than the older equipment may allow more wax particles through and that would allow the filter to go longer before it is plugged.
   / Treating diesel in north Texas winters #34
I keep 15—20 gallons of diesel on hand, servicing 2 tractors and 1RTV. Seems there is no typical winters in north Texas, I always treat my stored gasoline, but in the past have not treated diesel. But until this year usually only kept 5 gal on—hand for by b kubota. All equipment today is stored under a 23x40 metal drive—in shed, so nothing gets wet or is exposed at all. Diesel is up off ground at all times in a 15 gal plastic container with a hand pump and put it through a filter funnel.
would you treat or not, and if so, what works best in north Texas, zone 8A.
Considering alot of information came from over 1k miles North of him I'm not sure OP found what he want's to know. #1 problem effecting gasoline and diesel in Texas is water from condensation. Humidity is always high and 30f swings within a 24 hours and 50f within a week is common. Fluxation in temperature causes fuel tanks to "inhale and exhale"for lack of a better term. Droplets of water collect on tank as the result. Ethanol in gasoline obsorb's water and alows it to burn with no ill effect. A certain amount of water can be a blessing in de-carbonizing combustion chamber. When ethanol reaches saturation point,farthar condensation become's free water that can't burn which result's in poor engine performance. Keeping tank topped off and a water seperator in fuel line is both effective and efficient. "Nuff bout"gasoline. Moisture that condensate's in a diesel tank remains until it's pulled out by fuel pump. Unlike gasoline engines that will burn small amounts without effecting performance or damaging engine,the smallest amount of water can interfer with fuel delivery or if it get's by seperator, damage diesel engines. I expect most everything I say will be poo pooed in one fashion or another but if you don't 100% trust what I'm about to say,research with experts,not interweb buds,not Tha said or I herd,experts. Never treat diesel with anything that perport's to solve water problems. The only thing water treatment does is trick seperator and filter to alow water to pass and cause damage.
To the origional question about treating stored diesel,a clean,air tite plastic can will store diesel without treatment unless you decide to pour it at freezing temperature,it might gel. The reason different people report different experiences with gelling is pretty simple. High volume truck stops always include anti-gel during winter. A truck fueling in Houston might be heading to Duluth and Flying J doesn't want their fuel gelling and causing them to lose an account. Stand's to reason many other stations are supplied by same refinery as truck stop so they also have anti-gel. On the same day truck fill's with anti-gel diesel,a ship 20 miles away is taking on off road diesel that doesn't include anti gel. The same refinery supplying off road to ships may very well supply farm stores in the area. Mid summer around the Great Lakes chances are no place has anti gel so a man buying 5 gallons might be in for a suprise if he store's it until December.
With that taken care of,the news media in typical fashion skewed the truth about the Texas cold spell last Febuary. Temperatures weren't intolorable nor were Texans a bunch of candy azzs. The intire problem was a bunch of buracrates in charge of overseeing power grid hadn't been doing anything but sitting in offices drawing wages they never earned.
Thanks Jaxs for a Texas perspective, and you are spot on about the cause of last winters problems.
   / Treating diesel in north Texas winters #37
The company that removed 1800 trees of mine showed up late December and we were hit with a cold snap. The feller buncher and hydro-ax still ran but the big chipper was gelled up. They sent chipper #2 up and that was gelled until they got it going. I had $3M worth of equipment sitting for a week until it warmed up enough to run. Being gelled cost them the down time, having to truck another 60 ton chipper, the multiple service truck visits etc.
   / Treating diesel in north Texas winters #38
You only gell once!
Especially if you had to walk a mile, heat, boost (learn new words).
I use an additive ever since it happened to me.
Me too. Once. That was 30 years ago. If it ever happens to me again it will be when I'm too old to remember whether I treated or not. All of my tractors are sitting with the tanks full of treated fuel right now.
   / Treating diesel in north Texas winters #39
I've custom farmed with diesel powered tractors in N Texas since 1987. The only time I add anti-gel fuel conditioners to my tractors fuel tanks was when temp was forecasted to be below 20°F & I intended to use tractors. In my old age I don't add any anti-gel because I don't plan on starting the tractors at that ambient temp.
2011 Ford Edge AWD SUV (A56859)
2011 Ford Edge AWD...
New/Unused 14ft Bi-Parting Iron Gate (Elk Design) (A57453)
New/Unused 14ft...
1986 Ford LNT9000 Dump Truck (A56436)
1986 Ford LNT9000...
DRILL CABINET SKID (A58214)
DRILL CABINET SKID...
2020 John Deere 304L Wheel Loader w/ LM90 Worksite Pro Bucket (A56438)
2020 John Deere...
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
