ernemats
- Joined
- Mar 29, 2002
- Messages
- 1,103
- Location
- Bolivar, pa.
- Tractor
- power trac 422, and agco-allis 5660, ,1845 power trac Greenworks CRT 426
Has anyone had any problem with the older pt's that have a cable to operate the treadle to the hydroback? Friday I went to use mine and when you leave up on the forward or reverse pedal it does not return to the center position the way it should. I called PT and talked to Terry he feels that the cable might be worn, he said they very rarely have any problems with the hydroback. I checked the treadle assembly to make sure dirt or grass was not built up to interfere with its operation, it was ok. The forward reverse work fine it just does not seem like the cable or hydroback have enough tension to return to the center position. Terry said to disconnect the cable at the treadle to see if pedal centered without any resistance and to clean it out real good with the pressure washer and to grease it then which I did, still the same. I think it has to be either the cable or the hydroback where the problem is. My pt is a 422 purchased in 2000 with 900 hours on it . Any suggestions on how to check those 2 things to find the problem?
