Trany/hydraulic dip stick securing.
   / Trany/hydraulic dip stick securing. #1
Ewgoetz
Bronze Member
Venice, fl
Massey ferguson
I'm using my massey to clear out a lot of palmettos from a property I own. Last week I went to check the trany fluid and saw the dip stick was missing. Pretty sure of the area it might of gotten yanked out at but with out a metal detector I'm pretty sure I'll never find it. It may have even worked its way into the palmetto/brush piles I have made.
Anyway has anyone figured a way to secure the dipstick so it can't be yanked out? Maybe a little chain to it or some sort of locking setup? I just got a new one in today and really don't want it to disappear again while yanking out the palmettos again.
   / Trany/hydraulic dip stick securing. #2
It looks like three different dipsticks are available from Agco. One looks like it has a loop that a wire or chain could be fastened to prevent loss. Do you have differential lock, the dipstick is in close proximity to the engagement pedal and maybe your foot pulled it out. This may be a stretch but the lift cover is supposed to have a breather assembly on the left side under the seat. If it is plugged or has been removed and plugged, quick changes in the fluid level with the three point or the auxiliary hydraulics may be causing excessive pressure in the housing and may have blown the dipstick out. I have never heard of this or am sure it is even possible but may be an explanation. Hope you solve this.
namyessam
looked again at agcopartsbook.com and see two of the dipsticks are superseded and only one is available. Still a wire or chain connected to it would prevent loss or it ending up in a tire as it would with my luck.
   / Trany/hydraulic dip stick securing. #3
I'''l Be Danged ,I thought I had heard it all!!!!!.
HUtch.
   / Trany/hydraulic dip stick securing. #4
Just a handy fact .
If one was to Misplace or loose the Transmission dipstick ,by removing the Bottom SETSCREW/BOLT THAT SECURES THE RESPONSE LEVER/ DIPSTICK COVER oil will run out of the hole if not fill with oil till it does no dipstick required !!
Happy Days.
Hutch.
   / Trany/hydraulic dip stick securing. #5
Just a handy fact . If one was to Misplace or loose the Transmission dipstick ,by removing the Bottom SETSCREW/BOLT THAT SECURES THE RESPONSE LEVER/ DIPSTICK COVER oil will run out of the hole if not fill with oil till it does no dipstick required !! Happy Days. Hutch.
Hutch, your post are both amusing and informative. :thumbsup: -kid
   / Trany/hydraulic dip stick securing. #6
I have a small link chain attached to the hyd dip stick which is by my left foot.i have raised the dip stick with my heel the chain keeps it from getting lost.
   / Trany/hydraulic dip stick securing. #7
G'Day deerseeker.
I think you have the wrong colour red ,May be better to post on the International Site !!!
Regards.
Hutch.
   / Trany/hydraulic dip stick securing. #8
G'Day deerseeker.
Regards.
Hutch.
A bit offtopic.. Did you get that brush fire out?
   / Trany/hydraulic dip stick securing. #9
G'Day Kid.
The fire is now officially under control, unfortunatly there were 55 homes destroyed and at the height of the battle more than 128 fire units mainly Volunteers like myself ,fortunatly no loss of life.
At this point in time the fire was started by an overhead power pole on private property shorting out .
Thank you for your concern .
regards.
Hutch.
2010 UTILITY TRAILER MFG. CO. 53 FOOT FLATBED TRAILER (A53843)
2010 UTILITY...
1968 CHEVROLET C10 1/2 TON PICKUP TRUCK (A53426)
1968 CHEVROLET C10...
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
2007 Yamaha Rhino 660 (A53473)
2007 Yamaha Rhino...
2018 CHEVROLET 1500 SINGLE CAB TRUCK (A51406)
2018 CHEVROLET...
2020 Nissan Pathfinder SUV (A51694)
2020 Nissan...
