transporting fuel
   / transporting fuel #1
pipe_welder
western N.Y.
Kioti Ck 25
My friend just converted over to gas for heating. And is giving me the old tank and fuel. How much can I transport in 55 gallon plastic drums at a time? And He thinks its the cold weather blend from last winter any problems with using that in my tractor and storing it longer with the proper treatment?
   / transporting fuel #3
Get a Mr. Funnel and filter it. Then, mix it with fresh diesel.
Bob
   / transporting fuel #4
If the tank is full (275 gal.) it will take 5 - 55 gal drums to empty it. At roughly 8 lb per gal. each 55 gal drum will be about 440lbs. If loading them on a trailer you could do all 5 - 55 gal. drums plus the empty tank. just secure them very well so they don't tip over. If hauling in the pickup do 2 at a time to be safe. I recently bought 2 275 gal. tanks and each had about 100 gal. in them. They were loaded on my trailer with a fork and I chained them down and made the 20 mile trip home. Unloaded them with chains wrapped around them using a loader. Drained both tanks through a filter to a third tank. Fuel was good in both the ones I got.
Winter blend around here is usually 50/50 diesel and kerosene. I have used it in my tractor but not on a steady diet since kero doesn't lubricate as well as #2 diesel. I'd add more diesel to it if your going to use it on a regular basis.
   / transporting fuel #5
Other lubricity addatives could be added.
My concern is the plaquard necesity. Anyone know what # plaque that is?
Soundguy
   / transporting fuel #6
Soundguy
The # is 1993- Fuel Oil
If the total quantity is under 119 gallons, then placarding should not be necessary. Plus since diesel is not flammable, the rules are a little less restrictive.
   / transporting fuel #8
Yep.. I just went out an looked at my fuel rig.. couldn't remember. I have a 35g grease key i cleaned and painted yellow and have a hand pump in it. I mounted it to a 2 wheeled dolly. I just run it up on my trailer when i get low on fuel and take it to the station. I threw the plaq on there just in case I got in an accident.. that way the responders knew I was carrying a combustable liquid.
Soundguy
   / transporting fuel #10
Soundguy
The fuel depot I buy my OR diesel from, only 50 gallons max at a time, gave me the 1993 placard sticker. I use it at home on the barrel which I painted yellow. I am not so worried about trasporting fuel but the firemen putting my house out worry about these things too. Yellow is supposed to be a universal diesel color isn't it?
I have also heard the 120 gallon max figure for fuel hauling. It follows that most fuel transfer tanks made for mounting in pickups are really cloase to that volume.
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
2014 BMW X3 AWD SUV (A50324)
2014 BMW X3 AWD...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
