Transporting BX2350 w/FEL on Utility trailer
   / Transporting BX2350 w/FEL on Utility trailer #1
PA-Kubota
Apollo PA
2008 BX2350
Anyone have any photos or videos on how to tiedown a BX2350 with FEL and MMM on a utility trailer?
Thanks
   / Transporting BX2350 w/FEL on Utility trailer #2
6.5 x 12 load area. BTW I have 4 3inch ratchet straps ready
thanks
   / Transporting BX2350 w/FEL on Utility trailer #4
Does it have brakes?
   / Transporting BX2350 w/FEL on Utility trailer #6
I used the loader mounting frame for both the front & rear tie down points On my 7 x 10 trailer. This provided the best angle on the straps for both fore - aft & side to side. Also left in gear and the brakes for maximum resistance to moving.
Watch for sharp edges so that the straps don’t get cut or frayed. Check the tightness often since they can loosen
No brakes and not required in PA for under 3000 GVW which I figure I'm about 2600lbs total including trailer. My vehicle is rated over 6000lbs.
   / Transporting BX2350 w/FEL on Utility trailer #8
Hard to say without being there, but I壇 be all but certain to back the tractor on the trailer. Last thing you want is negative tongue weight. And you will be using about all of that 12 if you put the bucket on the deck where it belongs.
   / Transporting BX2350 w/FEL on Utility trailer #9
Agreed. Negative tongue weight and single axle. The tail will wag the dog.
As far as tie downs, the book calls for two tie down "points" on the tractor, and an additional one for the attached equipment. (FEL) I know this is overkill, but you asked. I'm assuming that you want the legal answer to your question.
Now, how would I do it, if it were mine? Probably back it onto the trailer. Tie down the rear hitch to somewhere on the tongue, and throw a ratchet strap over the floorboard.
I mean, we are talking about an overgrown lawn mower here! :p :eek: No offense intended. ;)
   / Transporting BX2350 w/FEL on Utility trailer #10
That trailer has a fairly good setback on the axle so most likely you'll be ok pulling on, I'd try it first and see how the tongue weight looks.
2015 Ford Explorer AWD SUV (A50324)
2015 Ford Explorer...
KJ 20'x12' Livestock Metal Shed (A50121)
KJ 20'x12'...
2012 RAM 5500 (A52472)
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2019 Bobcat E26 (A50120)
2019 Bobcat E26...
2014 Gillig G27B102N4 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig...
