Transporting barrels of water...
   / Transporting barrels of water... #1
aczlan
Good Morning
Northern Fingerlakes region of NY, USA
Kubota L3830GST, B7500HST, BX2660. Formerly: Case 480F LL, David Brown 880UE
I built a trailer over the winter (still need to paint it) and am looking at the possibility of hauling water on it for various purposes. The deck is 42" wide and ~60" long.
I am debating one of the following barrel configurations:
1. 4 Barrels vertically in a square on a pallet:
Benefits:
  • Not much sloshing due to less surface area on top
  • Efficient use of space
Downsides:
  • Hard to plumb (have to add 4 bulkhead fittings in the bottom)
  • Hard to tie down
2. 3 Barrels stacked and a 4th behind:
Top view: TrailerBarrelsSide_Top.png Side View: TrailerBarrelsSide_Side.png
Benefits:
  • Easy to tie down
  • Easy to plumb
  • Low COG
  • More water usable (top 2 barrels will drain into the lower ones
Downsides:
  • Less deck space available
Anyone have any thoughts?
Aaron Z
   / Transporting barrels of water... #2
Remember that water weighs about 8 pounds per gallon...
   / Transporting barrels of water... #3
I don't know how much money you have to spend,, but I have seen on craigslist water tank for less than 100 buck,, made of plastic and metal screen cover with a drain valve on the bottom.. I believe they are 275 gal tanks.. full would weight about 2300 pound plus tank and screen.. anyway a thought.. Lou
220 gallons of water will weigh 1760#, there is a 3500# axle under the trailer and it will be pulled with either the RTV500, or the B7500 either of which will be fine with that much weight.
I plan to have some straps to hold the barrels down to the frame and more to hold everything down to the trailer.
Aaron Z
I don't know how much money you have to spend,, but I have seen on craigslist water tank for less than 100 buck,, made of plastic and metal screen cover with a drain valve on the bottom.. I believe they are 150 gal tanks.. full would weight about 1300 pound plus tank and screen.. anyway a thought.. Lou
Have seen those, but only in 275-300 gallon sizes. I dont really need that much water (will be filling it and using it to water trees and have water out back by the fire pits) and it would just slosh around in the larger tank which could make driving (and more importantly, stopping) interesting.
We currently use a 30 gallon tank of water for trees every other day and it lasts a week (3 gallons/tree X4 trees)
Aaron Z
   / Transporting barrels of water... #10
if it's 300 gal tank it would only weight about 2500 pounds,, you have 3500 axles,, shouldn't be a problem.. Lou
UNUSED WOLVERINE LL-12-78W 78" LAND LEVELER (A54757)
UNUSED WOLVERINE...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
2006 NEW HOLLAND L185 SKID STEER (A52705)
2006 NEW HOLLAND...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
