Transporting a BX22 ?
   / Transporting a BX22 ? #21
I looked closer this morning. This is data from the Dodge/Cummins owner manual, 2001. This book covers 2500 and 3500 series Dodge trucks(3/4 and 1-ton). From pg152 and 168:
"Trailer brakes are recommended for trailers over 1000lbs(454kg) and are required for trailers in excess of 2,000lbs(907kg)."
1000 lb recommended, and 2000 lb required weights are pretty low. To give a relative example, my '01 2500 Quad Cab 4x4 long bed is specced for a max trailer weight of 11,300 lbs. Niether the book nor my truck list the curb weight. I was on a scale a few weeks ago though. With ~400lbs in the back, and the 1600lbs of my 16' flatbed trailer, I weighed at 8850lbs. So, that puts my curb at about 6800lbs.
This is a guess, but I would think that the Ford and GM offerings are similar. No idea on the Mazda/Nissan/Toyota.
As far as brakes go, mine was soooo simple to hook up. The truck has trailer package, with a 7-wire plug at the back. It came with a wiring connector for the brake controller. I hooked the four wires from the connector to the brake controller, and I was up and running. My neighbor has a 2000 Chevy 1/2 ton Z71 that was the same way. It took him just a few minutes to hookup and install the controller. I know the Ford is the same way too. Again though, I do not know about the newer Mazda/Nissan/Toyota.
On my old '89 Ford F250, I ran the wires. It was pretty simple. The turn signals and brake lights were simple; I got a 7-wire plug-in adapter from Checker/Kragens auto. It "T'd" in at a existing wire harness connector at the back of the truck. That got me lights. For the brakes, I had to run power and ground from the battery to under the dash, a wire from the dash to the rear of the truck, and a short wire to the brake switch under the dash. While I was at it, I also added a Charge line, and connected to backup lights.
It did take a little while to do a clean, factory like installation. But, while towing a different 16' flatbed with the Kubota on it, I was glad I did it. I hauled a two horse trailer too, so I really had to have it anyway.
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
(INOP) MASSEY FERGUSON 2614H RIDING MOWER (A58374)
(INOP) MASSEY...
GRAIN BIN - APPROX. 14' ACROSS (A52708)
GRAIN BIN -...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56436)
2019 Krause...
3PT BOOM POLE (A52708)
